Old 07-14-2015, 03:11 PM   #1
Water heater on 2013 Cherokee 255S
Our water heater ignites & runs for sometime when we first turn it on. Once it's shut off we barely have warm water coming out when on hot, however the water dispersed from release valve is hot. All valves are running parallel with the line. Have we me missed something or turned a valve that shouldn't have been?
DeeAlta is offline   Reply With Quote
Old 07-14-2015, 07:22 PM   #2
No need to respond, I've figured it out.
Old 07-14-2015, 07:26 PM   #3
wmtire's Avatar
Do you want this thread deleted?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 07-14-2015, 10:22 PM   #4
Fulltime family RVer
Better than that- post the fix/resolution.
Old 07-14-2015, 10:31 PM   #5
The part (All valves running parallel to the lines) is a good clue! Youroo!!
youroo is online now   Reply With Quote
Old 07-26-2015, 12:34 PM   #6
The system is slightly different then our last trailer as all the connections were under the sink where the pump was, but this trailer the water tank, valves, pump are all located in 2 separate locations. Had asked the dealer to walk us through the winterizing and de-winterizing process, but would not allow us to be around when they were doing this even though the sales person indicated we could partake in the process. Lessons learned and now have the instructions and pictures to help. I find there's a learning curve and thankful for this forum.
2013, 255, cherokee, heater, water, water heater
