Old 04-24-2016, 08:47 PM   #1
Water Heater On/Off Switch
Hi all!
In poking around our new Wildcat Maxx TT, there is a switch on the main panel that seems to switch the water heater from propane to electric. Is there a separate switch that will shut the water heater off when not needed, or do I just shut off the propane supply?
I appreciate any comments and feedback!
2016 Wildcat Maxx T28RKX
USMC/USNR Seabee (SCW/FMF) Retired
VFW Life Member
Bob55 is offline   Reply With Quote
Old 04-24-2016, 09:09 PM   #2
raspivey's Avatar
I'm not familiar with that particular trailer, but most of the panels I've come across only have a switch for propane...some have an electric switch also. Haven't seen one with a switch from one to another. How is the switch labeled?
Old 04-24-2016, 09:24 PM   #3
bikendan's Avatar
Are you sure that switch does that?
Most FR products have Suburban WHs, which have the electric switch outside, on the WH itself.
The inside switch is propane only.
Post a pic of it or the brand and model number of the WH.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-24-2016, 09:37 PM   #4
wmtire's Avatar
Originally Posted by Bob55 View Post
Hi all!
If you do indeed have a Suburban water heater (not the tankless variety), then this FAQ may help out in understanding the switch(es).
Suburban's electric switch and much more
If you only have one water heater switch inside (Suburban model SW?DE), then it usually operates ONLY the propane/DSI.
If you have TWO water heater switches inside (Suburban model SW?DEL), then one is for the propane/DSI and the other is for the electric heating element.
Back to the RV's with only ONE inside switch (SW?DE), you may find a secondary switch outside on the face of the water heater that ONLY controls the electric heating element.
It's all explained in the link above, if this is the water heater you have
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 04-24-2016, 09:38 PM   #5
raspivey's Avatar
Now I wish I had looked to see what brand WH was in the 2017 models I was looking at a few weeks ago. I know the panel in those had gas and electric switches on it.
Old 04-24-2016, 09:42 PM   #6
bikendan's Avatar
Probably Atwood.
Old 04-25-2016, 12:13 PM   #7
Nelsflying's Avatar
Water heater on/off switch
I also have a 2016 Wildcat Maxx TT - Inside switch is propane, outside switch on the heater is 110 electric.
Nelsflying is offline   Reply With Quote
Old 04-25-2016, 02:23 PM   #8
Stormrider151's Avatar
I have an Atwood water heater. Two switches on the inside panel. One for gas and one for electric.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 04-25-2016, 02:30 PM   #9
Flybob's Avatar
Next time you have a 20 mins or so, open all the covers access doors etc and record the manufacturer, model and serial number on all your appliances WH, Fridge, AC, water pump etc. Keep a copy in the RV and one at home. They are invaluable when you need parts or advise. A build sheet is provided to the dealer by FR on every unit with that info, but unless you ask, the dealer usually does not pass it along.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-25-2016, 03:19 PM   #10
My 2015 Sabre has the inside propane switch and the electric switch outside on the water heater. My question is that I have turned the electric switch on and then forget about it. It is always on. Any problem doing this?
jrmorris is offline   Reply With Quote
heater, water, water heater
