Old 10-30-2013, 08:15 PM   #1
Water heater only getting lukewarm
I just recently purchased the camper and the hot water is only getting lukewarm. I've read a lot about the bypass valve in the back of the unit. This particular one had only the single valve on the cold line at the bottom. It seems to be open with flow. Do I need to close that valve or look for something else that could be wrong
strutbuster1 is offline   Reply With Quote
Old 10-30-2013, 08:20 PM   #2
Phat Phrog Stunt Crew
awwall's Avatar
You might want to check the thermostat. Most are set at 125 degrees.
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 10-30-2013, 08:25 PM   #3
Rugged Brown's Avatar
You also might want to check the bypass valve on the rear of the hot water tank. It may be in winter position.
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 10-30-2013, 08:30 PM   #4
The reset buttons on the thermostat haven't been tripped. It's only got one valve on the back of the water heater. It's on the bottom where the cold line is it seems to be open do I need to close it
Old 10-30-2013, 08:37 PM   #5
There should be 2 lines going into the back of the water heater. The supply cold line and the hot water line. Most times, these are connected with a bypass line and a valve. If yours is different, i expect more troubleshooting will follow from other posters.
Terry/Bernadette
Lily the Yorkie
Old 10-30-2013, 08:37 PM   #6
I think I attached a picture of the back of the unit
Old 10-30-2013, 08:40 PM   #7
That short line between the hot and cold needs to be closed by a valve. Looks like the valve was removed.
Terry/Bernadette
Lily the Yorkie
Old 10-30-2013, 08:42 PM   #8
That's what I was thinking. If the valve that's there was closed it would cut the water going into the unit off
Old 10-30-2013, 08:46 PM   #9
looks to me like the hot water coming out of the tank is mixing with the cold supply water line. Unless, the valve on the cold water line is supposed to close the bypass but is malfunctioning. My setup is different. I have 3 valves, one on each line, Hot, cold and bypass.
Terry/Bernadette
Lily the Yorkie
Old 10-30-2013, 08:50 PM   #10
Yea it seems to be mixing the two. If I closed that valve do you think it would help or would it shut the water off to the unit
heater, water, water heater
