Old 07-04-2011, 11:09 AM   #1
onequicksportster's Avatar
Water heater operation
Sorry I'm new here, I know i'm full of questions, please bare with me. I know how to turn on my water heater with gas, you turn it to on, and the red light lites up on the swith while the pilot is lighting,then goes out after its lit. My question is how do you use it on electric Thanks for any help..
2015 F250 psd CC Sb 4x4
2007 Wildcat 28rks 5'ver
2005 Harley Davidson
2009 Weimaraner "Dog"
onequicksportster is offline   Reply With Quote
Old 07-04-2011, 11:15 AM   #2
MtnGuy's Avatar
Making sure that there is water in the heater, turn the breaker on at your power center. Then, there is tiny toggle switch that is well hidden behind the gas line at the lower left section on the outside of your water heater. Many times there will be a cotter pin you need to remove before throwing the switch.
Old 07-04-2011, 11:16 AM   #3
I was wondering how do you start a thread how do you make your own because I have a question about slide outs and bow you remember to close all of the drawers around them before you put the slide out in because he Brice a drower and part if the slide out side wall on the inside p
Matthewsbj1 is offline   Reply With Quote
Old 07-04-2011, 11:22 AM   #4
Thank you mtnguy I would have never gotten this figured out.. Matthew, just go to the tread that best fits your question, go to the bottom and hit start new thread.. good luck
Old 07-04-2011, 01:09 PM   #5
Coupey's Avatar
Thanks for the info on this, just read the thread and rushed outside to look at our water heater and it has the exact switch. My question is do you need the switch on the main control panel on or off for the electric element to work or is it controlled just with the rocker switch in the heater as per the photo. Does it run of the 12v or 110v mains power. thanks
Coupey is offline   Reply With Quote
Old 07-04-2011, 01:16 PM   #6
grhodes50's Avatar
You do need the main breaker on for the electric side of your water heater to work. Some turn it on and off using the rocker switch at the heater itself while others leave the rocker switch on and use the breaker to turn it on and off. Your choice. Just make sure your water heater tank is full first or you'll be replacing the element. It only takes a few seconds to burn it up.
It runs off the 110v.
Gary & Trish
2018 Nights Camped - 5
Old 07-04-2011, 01:27 PM   #7
Send a message via AIM to jk31668
and yes, you can run gas and elect at the same time if desired. it does speed up recovery. for most situations however, i turn off the gas to save my propane and use their elect.
jk31668 is offline   Reply With Quote
Old 07-04-2011, 01:29 PM   #8
Coupey's Avatar
Thank you, we will try it this weekend if the site has enough amps, we have to watch our electric usage in the uk as sites only have between 10 - 16 amps and its often a juggling act of what to have on and off.
This site is great for learning, constantly getting tips and useful info
