You can get an element at Lowe's or Home Depot, and the socket you will need to change it. Remove all water pressure, whether city water or pump. Remove your electric AC power, (battery can stay connected). Turn the gas off to the heater. Also let the heater cool down. Outside, open the heater door, and near the bottom left you will see a black plastic cover, behind the burner tube. That is where the element is. You will need to remove the burner tube, and then the screw holding the cover on. Then remove the 2 wires that are screwed to the element. Doesn't matter which is which for reinstall, so don't worry about colors or location. Take your tool, and unscrew the element. Be careful, as water will come out when it is removed. I hope you let the water get cold. Make sure the new element, (1500 watt), has a good "O" ring on it, and screw it back in. As you can tell from the special socket, not a lot of torque is required, the socket won't take it. Reconnect the 2 electric wires, then the cover, ten the burners tube. Turn the water back on, and refill the tank. First, open the "pop off" valve, and when you get water there, go inside and open the hot water for the kitchen, then do the same in the bath. Now turn your electric AC back on, and switch your heater to electric. Now wait a few hours, have a beer or two, and see if it works. I know this sounds lengthy, but really, it's a 15 minute job. Good Luck.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
