Old 07-05-2011, 05:17 PM   #1
water heater problems
hello all, used the hot water tank for the first time this week and had some problems. Just let me say that I did fill the system with water and removed all air, all the valves are in the proper direction and it works great on propane. Problem: put in on hydro and within three to four minutes it pops the breaker. Any ideas, Thanks in advance. 2011 Rockwood 2604
bryanne7 is offline   Reply With Quote
Old 07-05-2011, 05:24 PM   #2
MtnGuy's Avatar
What breaker does it throw, the pedestal or the power center breaker ???
Old 07-05-2011, 05:25 PM   #3
You may have a bad element. I had this issue once. Also check the wiring to it and or the thermostat for the temp. I would lean more towards a defective element or broken wire.
2008 Rockwood 8281ss
2006 Dodge Ram Mega Cab Hemi
Reese 15k Slider
mikegp1 is offline   Reply With Quote
