Old 07-01-2015, 01:52 PM   #1
Water heater problems
Hi, we have a 2015 Forest River Wildcat 295 rxs that we are not able to turn the electric water heater. The gas works but there are black smoke marks outside the exhaust vent Is there another switch outside to turn on the electric water heater? Is the black smoke normal for a new unit?
roadk01 is offline   Reply With Quote
Old 07-01-2015, 01:54 PM   #2
wmtire's Avatar
See if this FAQ helps. It explains the operation, as well as the usual electric switch placement (if equipped), for the Suburban brand water heaters.
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
I used to be addicted to time travel, but that's all in the past now.
Old 07-01-2015, 02:05 PM   #3
Georgia Frog Rally 2017
aceinspp's Avatar
If so equipped go to the exhaust vent and open. Look behind the burner tube and to the left by the wall If you have a switch it should be there. Hard to see. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2015--46
Days booked for 2016--60
Days camped in 2016 so far 51
Old 07-01-2015, 02:06 PM   #4
Crockett's Avatar
good post by wmtire. as far as the smoke goes, you got a bad air/fuel mixture. this is usually caused by the a small spider that builds that solid white looking web in the burner tube. thats where I would look first. could be other causes...flue obstruction, orifice, lp pressure. get some lp leak fluid to test connections when your done. Attempt only if you feel its within your capabilities.
Crockett is offline   Reply With Quote
heater, water, water heater
