Old 09-04-2011, 04:38 PM   #1
Water Heater Question
Hey guys,
We have a Sierra 35 LOFTwith a gas/electric water heater. A while back, the electric part of the heater stopped working. Thinking it was a burned-out element, I replaced that. The old element did not look too bad but replaced it anyway. Still no electric hot water. All switches seem to be in the correct position and breaker is not tripped. Reset buttons are not sticking out.
Does anyone have any ideas?
Thanks,
Jake
Jake and Julie
TV: '07 GMC 3500 D/A DRW
5'er: Sierra 35LOFT "Tree House"
2 boys
2 dogs
jakenjulie is offline   Reply With Quote
Old 09-04-2011, 04:46 PM   #2
RV Newbie
buzzards27's Avatar
Are you testing with a meter to see if you have current? Work your way back to the breaker. I assume you checked the switch in the outside of the heater.
2005 FR Lexington 210 6.0L 8500 miles
2007 2500 Silverado Ext. Cab, 6.5' bed 5.7L
2010 Ford Fusion Hybrid
1963 Ford 861 5 speed with loader
1958 Ford 800 Select-O-Speed (parts tractor)
buzzards27 is offline   Reply With Quote
Old 09-04-2011, 04:59 PM   #3
I need to check to see if I have current. Will let you know. And yes, the switch o/s is on.
Thanks,
Jake
Jake and Julie
2 boys
2 dogs
Old 09-04-2011, 05:41 PM   #4
OK, no power at heating element. Checked for switch on and breaker not tripped. I assume power comes from breaker panel but I'm not comfortable messing with breaker. How do you cheack to see if breaker is good?
Thanks,
Jake
Jake and Julie
2 boys
2 dogs
Old 09-04-2011, 06:41 PM   #5
RV Newbie
buzzards27's Avatar
One way to test the breaker would be to kill the power to your rig and then switch the wires on two like sized breakers. If the heater works then and the other circuit is dead the fault is apparent.
Or if you can test the wire at the breaker with your meter. Red probe to screw on breaker and other probe to buds bar with all the white wires.
I have a circuit tester that signals when a wire is hot. If you have one checking along the route of the wire might lead you to a fault. Maybe the switch outside is bad.
Old 09-04-2011, 07:46 PM   #6
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Somewhere, near the back of the water heater, there is a receptacle that the water heater plugs into. Find it and plug in a lamp, nightlight or whatever.
dimurrrw is offline   Reply With Quote
