Old 04-03-2012, 08:19 AM   #1
JoeyO's Avatar
Send a message via Yahoo to JoeyO
Water Heater Question
I have the Atwood 6 Gal Water Heater, and had the opportunity to use it last weekend while camping. The WH has gas and electric options, I was using electric at the time. But my question is, I need to turn up up the temperature of the WH. The water was warm, but never got hot. Where is the knob located at to do so? This is a 2012 TT with the Atwood 6Gal WH.
Thanks,
OTeam
2018 Genesis G80
2010 370z Convertible 6 Stick
2011 Expedition 5.4L 4x4 Limited
2018 Highland Ridge 275 Light
Semper Fi
JoeyO is offline   Reply With Quote
Old 04-03-2012, 08:23 AM   #2
MtnGuy's Avatar
1st off, make sure your winterization bypass valve is completely closed. That seems to be the solution to about 95% of the "no hot water" issues here on the forum. A simple fix if that is the problem.
Old 04-03-2012, 08:32 AM   #3
TURBS's Avatar
Also you should be able to use gas and electric option at
The same time.
But I agree that your hw heater bypass isn't correctly turned.
Old 04-03-2012, 08:58 AM   #4
Water heater not getting hot enough
Check out this topic from last week.
Bill M
2012 Georgetown XL 360
2011 Chevy Equinox - 2006 Chevy Avalanche
Bill m is offline   Reply With Quote
Old 04-03-2012, 09:35 AM   #5
bikendan's Avatar
no such feature for temp that i know of. water temp is preset and non-adjustable.
probably what the others have said, is the issue.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-03-2012, 10:38 AM   #6
TURBS's Avatar
You can buy a "hot rod" electric heating element that does raise
you hw temp. But I have found all that's needed is both
gas and electric used at the same time to be sufficient during
brief showers.
Old 04-12-2012, 04:34 PM   #7
rracer5's Avatar
X2 on the temp control. There is NONE. Thermostat is preset and is somewhere in the area of 180 degrees. So, when you find the problem as has been previously suggested, use extreme caution especially if little kids are around and have access to the outside shower and you're not around.
During "high demand" usage (like back to back showers) run the heater on both electric and gas to facilitate faster recovery of hot water.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
Old 04-12-2012, 09:15 PM   #8
JoeyO's Avatar
Thanks everyone. I had the trailer home today and had a better chance to survey the valves going into and out of the water heater. I had the bypass open.
I read the info on how to and such, but I guess I wasn't familer enough - till today to fully understand what the bypass valve was and where it tied the two lines together.
Thanks again! Joe
OTeam
2018 Genesis G80
Semper Fi
Old 04-18-2012, 10:35 AM   #9
cre10's Avatar
brief showers.
Do you have a link for this?
2012 Chevy 3500 Duramax Crew Cab Z71 LTZ SRW
2012 Cherokee Grey Wolf 28BH
2011 F-250 6.2 Gas
2001 F-350 Powerstroke
1995 F-350 7.5L 460
Numerous Ford and New Holland Tractors up to 135hp. Bobcat 773.
cre10 is offline   Reply With Quote
