Old 04-16-2013, 06:31 PM   #1
Glockfanjohn's Avatar
Water heater question
Hi Guys and Gals....looking for some help!!! I opened up the trailer yesturday and dewinterized it. My hot water heater is gett ing warm but not hot like is should be. I have tried it using electric and gas and both eth same result. Anyone have any ideas???? Please help!!
Best,
John
2009 Silverado w/5000 lbs airbags and P3 controller.
2013 Rockwood 2702SS
US Army Veteran
Glockfanjohn is offline   Reply With Quote
Old 04-16-2013, 06:40 PM   #2
You didn't set the bypass valves correctly.
Old 04-16-2013, 06:50 PM   #3
Denver, CO
garbonz's Avatar
That's probably it.
2017 Fuse 23T
Old 04-16-2013, 06:59 PM   #4
kenandterry's Avatar
The same symptoms every time someone says "warm but not hot"
Check the by-pass valves. If there's heat at all, it's being restricted by the by-pass valves in the wrong position. If it wasn't working by heating even a little bit, the water temperature would be cold.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 04-16-2013, 07:00 PM   #5
TURBS's Avatar
Summer postion
Old 04-16-2013, 07:00 PM   #6
Isnt the bypass a 90 degree valve I thought it was on or off. What might I be doing wrong
Best,
John
US Army Veteran
Old 04-16-2013, 07:01 PM   #7
TURBS's Avatar
Winter position
Old 04-16-2013, 07:14 PM   #8
Denver, CO
garbonz's Avatar
Take a picture of the back of the water tank and we can critique.
2017 Fuse 23T
Old 04-16-2013, 07:34 PM   #9
The three valve system in the pics that Turbs posted is the simplest. His pics clearly show the positioning of all 3 for summer versus winter. Do you have 3 valves on your rig?
Ken and Terry
Old 04-16-2013, 07:45 PM   #10
I believe I only have 2
Best,
John
US Army Veteran
