Old 05-19-2016, 04:11 AM   #1
Water Heater Recovery Time
What is the approximate recovery time of a typical 6 gallon water heater, using both gas and electric sources?
2015 Micro Lite 25KS
2006 Suburban 2500 8.1 L
220Chap is offline   Reply With Quote
Old 05-19-2016, 04:19 AM   #2
nomad297's Avatar
About 15-20 minutes.
Bruce
Old 05-19-2016, 06:04 AM   #3
john5646's Avatar
X2, same here. Timed it at 14:00 minutes.
john5646 is offline   Reply With Quote
Old 05-19-2016, 06:17 AM   #4
KyDan's Avatar
We can take back to back "modified" navy showers and not run out of HW when both
electric and LP are on. By modified I mean we do shut off the shower head while lathering up but we also give it a little extra time on the rinse off.
Peace!
Dan & Rita D
Old 05-19-2016, 08:01 AM   #5
lesptr's Avatar
My wife and I regularly take back to back showers and we DO NOT use the navy shower method,and there is plenty of hot water to do dishes afterwards. I submit that if you have to navy shower, then there is a problem with the water heater.
2017 Coachman Chaparral 336TSIK
2015 F350 6.7
lesptr is offline   Reply With Quote
Old 05-19-2016, 08:35 AM   #6
john5646's Avatar
Here is what I've learned. A 6 gallon WH, nets 4.5 gallons of hot water, then the remaining starts to become Luke warm. ( this into a bucket to confirm amount. ) so run time is determined by water flow at shower head. For example a 1.7 flow rate should net 8 minute shower. (+|-) I've found just a little hot water at valve then turn cold on. Helps a lot.... This in addition to flow control valve
My WH from cold to hot as mentioned takes about 14:00 minutes.
Old 05-19-2016, 08:42 AM   #7
I worried about running out of hot water on my first couple uses. So I did my usual quick shower as most the time we are dry camping for a week. The last day I did the quick shower, washed all the soap off and then just stayed there with water running. Amazed I got about 5 minutes give or take of hot water before it got cool. That's on propane only.
clutchd is offline   Reply With Quote
cover, heater, water, water heater
