Old 09-23-2014, 06:25 PM   #11
I see the pic.now,NO Filter and the W/H valves are turned Wrong and it is putting Crap in the Cold side also! Youroo!!
Old 09-23-2014, 06:30 PM   #12
Its the old(We get a little Hot/warm water)then it turns Cold trick! Who does the Winterizing on your SunSeeker? Youroo!!
Old 09-23-2014, 06:40 PM   #13
Absnova's Avatar
We do it ourselves. Air the system out then antifreeze the tanks
Absnova is offline   Reply With Quote
Old 09-23-2014, 06:48 PM   #14
What is the (Orientation) of your 3 W/H bypass valves? Youroo!!
Old 09-23-2014, 07:00 PM   #15
Absnova's Avatar
So the three valves should not all be open. Whoops. Two years of usage but still feel like a newbie.
Old 09-23-2014, 07:07 PM   #16
deartruc's Avatar
Two hoses going to and from heater need to be open. Hose going between the two needs to be closed. But...if you don't use the water heater (or are winterizing, do the reverse. That way you can leave the tank empty. Also, do you notice the same rust or sediment problem in your house?
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 09-23-2014, 07:11 PM   #17
Absnova's Avatar
Thank you I will fix the hoses. The house we do not notice this type of sediment build up in any of the faucets or traps
Old 09-25-2014, 09:44 AM   #18
We bought this little wand type nozzle at camping world earlyier in the year, and used it to clean out the water heater. I couldnt beleive how much stuff came out, so I just kept moving it around and rinsed till it went clear. This was a used unit and never knew the mantaince that had been done prior. This nozzle will be going in the new trailer, and will probably use it at the end of the year when I drain for the winter.
Tim Myers
2013 Ford F-450
2015 Sabre 34 REQS-6
2018 XLR Boost 27QRB
dustym is offline   Reply With Quote
Old 09-25-2014, 10:07 AM   #19
PPST OGCDG
Frank-VA's Avatar
2250 water filter
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 09-25-2014, 10:09 AM   #20
Absnova's Avatar
Is it like the turbo wand? I use that for the black tank every time we dump to keep it clean. I am headed to tom raper's Rv parts store tomorrow to get a new rod.
heater, water, water heater
