Old 09-23-2014, 05:38 PM   #1
Absnova's Avatar
Water heater sediment concerns
We have a 2012 Sunseeker 2250 and love it. We do not use the hot water often but have not shutoff the water supply. Lately we have notice bad sediment getting into our whole system even the toilet. We have remove the toilet three times now to unclog the screen. I have had to clean out all the screens and even took a water hose to the water heater due to the large amount of sediment stuck in the bottom. What causes this and how do we stop it? We have even changed the rod each year. Help is appreciated!
Absnova is offline   Reply With Quote
Old 09-23-2014, 05:54 PM   #2
PPST Wannabe
kenandterry's Avatar
I'm not sure how/why you can use a rig a lot and not use/need hot water.
That being said, you source for water is apparently very dirty/cloudy. I would suggest you purchase an inline water filter............Camping World stores have a variety. Also, check your on-board water filter for if/when you use on-board water for dry camping/boondocking. Even a small screw on in line filter on the end of your water hose should be looked at and/or replaced. Changing the anode is only required when the component deteriorates due to bad water sources.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 09-23-2014, 05:55 PM   #3
TURBS's Avatar
You sure it's sediment and not construction debris?
If you have sediment in your wh there's no way to get it to the toilet.
If there is truly sediment in the wh you need to flush it.
do you have a good water filter?
Old 09-23-2014, 05:59 PM   #4
The (Hot) side of your system should NOT feed into your (Cold) side of your (Water Closet). Your water system after being used for a short time should purge any (Factory assembly debris) downstream. Did you place a Element Cartridge in your Filter? Youroo!!
Old 09-23-2014, 06:00 PM   #5
Absnova's Avatar
We have city water that we fill up with every weekend. We camp at race tracks that do not have hook ups like camp grounds. We take showers at the track instead of in the camper so I rarely use the hot water. When we closed the supply to the water heater the pump did not sound right like our water flows through the heater as a supply path even to the cold. Strange I know. We do not have a filter set up on the rig and the sediment was some of the rod pieces and white sandy like stuff. I say calcium but hubby doesn't agree.
Old 09-23-2014, 06:01 PM   #6
Absnova's Avatar
If it came with a filter where is it hid?
Old 09-23-2014, 06:02 PM   #7
TURBS's Avatar
You Definitely need a filter to prolong you water system life.
Filter should be right near the water pump.
Old 09-23-2014, 06:03 PM   #8
Absnova's Avatar
Would an external on the hose at time of fillup be a good idea? Limited space issues.
Old 09-23-2014, 06:05 PM   #9
TURBS's Avatar
Originally Posted by Absnova View Post
Would an external on the hose at time of fillip be a good idea? Limited space issues.
It cannot hurt.
But best to have an on board filter before the pump.
Most units after 2000 came with filter and housing from the factory unless it was removed by a previous owner.
TURBS
Old 09-23-2014, 06:22 PM   #10
Absnova's Avatar
Ours was new off show room floor. But I cannot find a filter anywhere.
heater, water, water heater
