Old 11-05-2017, 10:43 PM   #1
SlfMdeFam's Avatar
Water heater size
I️ have a Rockwood 2780WS. Iíve looked high and low to find the water heater size and canít find it. Anyone know the size? We took our trailer out this weekend for the first trip and with the electric and gas switches on for the water heater each one of us ran out of hot water. I️ have always turned the shower head off while soaping up and I️ even ran out.
SlfMdeFam is offline   Reply With Quote
Old 11-05-2017, 10:46 PM   #2
bikendan's Avatar
It's either 6 or 10 gallon
Equalizer WDH
Old 11-05-2017, 10:51 PM   #3
SlfMdeFam's Avatar
Chances are i have a 6 and even that sucked.
Old 11-05-2017, 11:02 PM   #4
FrankG's Avatar
There was a thread about the water heater issue about a month ago. I think it turned out to be a bad valve allowing cold water to infiltrate the system before the hot water. You should be able to get a shower out of 6 gallons, we did.
2018 Haulin 6 x 12 Cargo Trailer by Forest River (A legal Tow )
2017 Laredo 325RL
2016 Vengeance 29V Sold
2016 Ram 2500, 4x4 Laramie CCSB 6.7 Cummins
FrankG is offline   Reply With Quote
Old 11-05-2017, 11:03 PM   #5
Kasual Kamper
Originally Posted by Chris Allen View Post
...and with the electric and gas switches on for the water heater each one of us ran out of hot water. I️ have always turned the shower head off while soaping up and I️ even ran out.
Make sure the middle bypass valve is closed. I had a similar problem. See this thread.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 11-05-2017, 11:09 PM   #6
SlfMdeFam's Avatar
Thank you. I checked that thread from your recommendation so Iíll definitely check it on my trailer in a couple weeks before our next outing.
Old 11-05-2017, 11:09 PM   #7
SlfMdeFam's Avatar
Thanks. Iíll be checking that.
Old 11-05-2017, 11:14 PM   #8
You need to learn to take Navy showers. Get wet, turn it off, soap up, rinse down. Can't take a 5 min shower like at home.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 11-05-2017, 11:18 PM   #9
SlfMdeFam's Avatar
All due respect sir this is my 7th rv in 15 years and my 3rd FR And never once have i ever ran out of hot water. Thereís obviously something wrong in this unit. Furthermore i do turn off the head while soaping up like i said in my OP. Thanks for the feedback.
Old 11-06-2017, 08:49 AM   #10
All due respect sir this is my 7th rv in 15 years and my 3rd FR And never once have i ever ran out of hot water. There’s obviously something wrong in this unit. Furthermore i do turn off the head while soaping up like i said in my OP. Thanks for the feedback.
Sorry. You sounded like a newbie, as you didn't mention prior experience.
If you have a Suburban, the size is part of the model number: SW6DE, SW10DE, SW12DE, SW16DE. The number is the gallons. If you have an L at the end, then it has a switch inside the TT to turn it on with 110VAC, in addition to the normal outside switch.
Atwood appears to be similar, e.g., G6A-7 and GC6AA-8 are 6 gal, G10-2 and GC10-A2 are 10 gal.
heater, water, water heater
