Old 09-03-2013, 06:20 AM   #1
Grandmashome
Water Heater SW6DE - frame/access door
I have the suburban SW6DE - I switch on the propane for 10 minutes to heat - then shut off before fully heated so that the drip from the pressure valve doesn't go between the water heater frame and the housing to the wood/steel frame of the RV. What sealant do I put at the bottom between the frame and the water heater housing to keep the weep from going to the frame?
grandmashome is offline   Reply With Quote
Old 09-05-2013, 06:44 AM   #2
Old Enough to Know Better
gasman6674's Avatar
Any good silicone sealant will work, But you need to change your relief valve (aka T & P) it should not weep at all.
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle. 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 09-05-2013, 06:49 AM   #3
TURBS's Avatar
Gassman is correct the prv shouldn't leak at all.
It eithrr has debris in the valve causing it to leak or its defective.
Turbs
door, frame, heater, water, water heater
