Old 12-13-2014, 11:11 AM   #1
Water Heater too small
Can I install a 10 gallon water heater in my 2015 Wildwood 31QBST.
tay99john is offline   Reply With Quote
Old 12-13-2014, 11:21 AM   #2
rracer5's Avatar
If you have the room, I think a 10 gallon will fit. I think they're just taller. Otherwise all else is the same.
2014 Prime Time Sanibel 3250
rracer5 is offline   Reply With Quote
Old 12-13-2014, 12:48 PM   #3
Witch Doctor's Avatar
I guess you you can with some cutting and remodel. A 6 gal W/H = 123/4 x 123/4 x 193/4"'s a 10 gal is 163/8 x 163/8 x203/4" so it is the height and width that would be a problem, cutting into the side of the unit, not so much the depth of the unit. I guess it's also where it is located, but that's what your looking at for 4 more gals. ... Change your stat so you can make hotter water and not use as much would be my choice....Good Luck
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-13-2014, 01:32 PM   #4
Learn to take GI showers. 6 gallons should be plenty for most RV needs
donniedu is offline   Reply With Quote
Old 12-13-2014, 01:36 PM   #5
An efficient shower head can double your shower time
Have you tried changing shower heads? We found that the oxygenics shower head almost doubled our shower time, it also increased to a more satisfying spray pressure. Oxygenics 26181 Chrome Smart Pause RV Shower Head
RambleOn is offline   Reply With Quote
Old 12-13-2014, 01:56 PM   #6
We do both post 4 and 5 and use the propane with electric for faster recovery but it's only 2 of us. But we never run out of hot water. That's a great shower head. If I'm at a CG with a clean shower and my back hurts I hike up there to get some good old hot water on it for awhile. Other then that I always use the one in the trailer.
Coachmen M/H
Concord
2018 / 300 DSC
Old 12-13-2014, 02:12 PM   #7
Change both hi limit thermostats to the 140 degree ones and you will automatically use less hot water.
Old 12-14-2014, 11:59 AM   #8
Another option is to install a 2nd 6 gallon WH, plumbed in series with the original. You can even put it on the other side of the camper if that is where you have room.
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 12-14-2014, 12:25 PM   #9
rracer5's Avatar
I forgot about having to cut the opening larger on the outside.
water, heater
