Old 09-17-2012, 10:10 AM   #21
One other thing too.
When water does come out the pressure relief valve (water pump off, hot water tap on), it feels like there is some resistance when I lift the valve.
When water does not come out the pressure relief valve (water pump on, hot water tap off), it feels like there is no resistance when I lift the valve. I can just freely flip it up & down with my pinky.
paulmlac is offline   Reply With Quote
Old 09-17-2012, 10:28 AM   #22
Originally Posted by KyDan View Post
Sounds like your pressure relief valve is clogged which is pretty rare.
IF you get hot water out a faucet but not out the safety valve it must
be clogged somehow.
OP gets water out of the PR valve when the pump is off, so the PR valve wouldn't be clogged. Something is definitely amiss as none of this makes sense.
Old 09-17-2012, 10:48 AM   #23
Herk7769's Avatar
Bad valve I am thinking.
This is dangerous and your valve needs to be replaced.
HAM CALLSIGN - KC3FFW
Old 09-17-2012, 03:50 PM   #24
KyDan's Avatar
Less than $10 at Home Depot and also available at most any larger
hardware store and plumbing supply or home center.
3/4 in. Cast-Brass FPT 150 lb. Temperature and Pressure Valve-100XL at The Home Depot
Be sure and use plenty of teflon tape or oatey pipe dope with teflon on the
threads of the new valve.
And always remember-- Lefty-loosey Righty-tighty
Old 09-17-2012, 09:03 PM   #25
OP here -
Just so I understand, it sounds like water should come out the pressure relief valve anytime I lift the little finger switch so long as there is water in the heater.
So when I'm just sitting in a campground, using the fresh tank, water pump is on, water heater is on, if I lift the finger switch on the pressure relief valve, water should come out then right?
Should it be immediate or do I need to hold the finger switch up for awhile?
I have only lifted the finger switch for a second or two, not sure if I need to wait longer.
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
Old 09-17-2012, 09:06 PM   #26
Originally Posted by paulmlac View Post
OP here -
Should be immediately when the lever is lifted.
Old 09-17-2012, 09:18 PM   #27
Road-King's Avatar
OP here -
With either;
Water in the FW tank and the water pump "on"
-or-
Hooked up to city water and the water turned on at the outdoor water spigot
When you pull the pressure release valve, you will get air until the HW tank is full of water. Then you should get water whenever you pull it, if one of the first two conditions are still met...
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 09-18-2012, 07:44 AM   #28
KyDan's Avatar
If you can open a hot faucet inside and get water immediately you should
also be able to pull up on the water heater pressure relief valve and
immediately get water.
