Old 09-15-2012, 04:18 PM   #1
Water heater use
We have a new RV with a DSI gas / electric water heater. To ensure there is water in the tank prior to starting the water heater, is it enough to just run a hot tap (with water pump on) until water flows fairly easily without a lot of sputtering? Or should I do something with pressure relief valve also? Thanks!
All previous rigs below are sold - waiting until the kids graduate to the buy the next one!
'13 Forest River Sunseeker 3100 Class C
'04 Fleetwood Sedona Pop Up / Reese Mini 350 / Prodigy / BAL
'94 Coleman Cedar Pop Up
paulmlac is offline   Reply With Quote
Old 09-15-2012, 04:55 PM   #2
TURBS's Avatar
Do through pressure relief valve while filing tank
Old 09-15-2012, 05:46 PM   #3
How long would I hold up the valve and let water flow out? Thanks!
Old 09-15-2012, 06:06 PM   #4
MtnGuy's Avatar
To add a little to Turbo's post. It is always a good idea to get a little water out of the pressure relief valve when filling your tank. A little air up near the top isn't bad, but it is possible to have water at the faucets and still not have water in the water heater. That could happen if you still have the bypass valves set for winterization. Getting some water out of the pressure relief valve is a way to make certain the tank is full.
Just a little dab will do ya.
Old 09-16-2012, 03:54 PM   #5
For the heater tank, it draws water from the fresh tank or city water hookup?
tntrac is offline   Reply With Quote
Old 09-16-2012, 04:43 PM   #6
MtnGuy's Avatar
Which ever water supply you are using. The city water supply typically connects with the camper water pipes near the onboard water pump outlet.
Old 09-16-2012, 06:11 PM   #7
Trailer Trash
Just move the lever for the pressure relief valve a little. Water should dribble out right away when the hot water tank is full.
Don't flip the lever trying to fully open the valve. This is a pressure relieve valve not an on off valve. If you keep playing with this valve, the seal will probably go bad and end up with a leak/drip and then it's time for replacement.
joelek is offline   Reply With Quote
Old 09-16-2012, 07:31 PM   #8
J_KHawthorne's Avatar
Good advice here! If the PR valve dribbles, you're safe.
Jim & Kathy
2012 Crusader 290RLT TE, TrailAir flex pin: 2012 Toyota Tundra 5.7 SR5 Dbl cab 4X2 Tow, 4.30 gears, RideRite air, TRD cold-air induction & dual exhaust: Reese 16K Slider: TST tpms
Miles towed to date: 18,950 Nights camped 192
J_KHawthorne is offline   Reply With Quote
Old 09-16-2012, 09:15 PM   #9
Thanks for the advice. In playing with the pressure relief valve this weekend, I noticed the following:
- When I had the water pump on, hot water tap off, & lifted the valve, no water came out from the valve
- When I had the water pump off, hot water tap on, & lifted the valve, water came out from the valve
Not sure if that's normal or correct but that's what it was doing.
Old 09-16-2012, 11:40 PM   #10
Thank you.
