Old 04-27-2016, 06:23 AM   #11
nomad297's Avatar
Originally Posted by Oakman View Post
My 2003 Wildcat had the one valve system and I never had any problems or issues with this setup.
The single valve system works if there is a check valve on the hot side of the water heater.
Bruce
Old 04-27-2016, 06:31 AM   #12
wmtire's Avatar
As stated in the FAQ, you may have only one, possibly two, and could be three valves in the water heater bypass setup. They all work the same in principle, which is to bypass the water heater and connect the cold water line to the hot water lines and allow anti-freeze to be pumped into both lines thru the cold water side/pump. The one valve system as you have utilizes an internal check/backflow valve on the hot water outlet side.
With the one valve system, like you have..... when you open the crossover valve, it actually closes the cold water inlet line feeding the water heater. This is connecting the cold water line to the hot water line for anti freeze purposes....but as others have stated, you have nothing feeding the water heater itself and thus when you turn on the taps inside your RV, ALL the water coming out of the hot water taps is coming from the cold water line via the crossover valve being set that way.
You need to turn the valve such that it CLOSES the bypass line and OPENS the cold water inlet line to the water heater......so water can enter the heater. You can actually think of the valve handle itself as an arrow and point it to the direction you want the water to flow. You have it pointing to the crossover line. You need to point it to the water heaters COLD water inlet line.
When you turned on the propane to heat the water, if there is no water in the heater then the thermostat turned off the fire when it sensed the temp getting too hot. It may have also activated the ECO hi-limit temp part of the the thermostat assemble you may have to manually reset.
It's hard to know at this stage if you had no water in the heater, not knowing how you may have turned the valve, how many times, and if the heater was drained. As also explained in the FAQ I posted, you can flip up the pressure relief valve on the water heater to see if there is water in the tank at all.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 04-27-2016, 06:38 AM   #13
Cherokee1979's Avatar
The valve doesn't switch towards the cold water it turns straight up or to the left.
Cherokee1979, Cherokee27L, ChevroletZ71 5.3
Cherokee1979 is offline   Reply With Quote
Old 04-27-2016, 06:42 AM   #14
wmtire's Avatar
Same difference, turn it left and it will close the crossover line and open the inlet line to the water heater.
Old 04-27-2016, 06:44 AM   #15
I flipped the pressure relief valve and no water came out ,BUT I pulled the anode rod out and water flowed out for a while so I know it was full of water. I put the anode rod back in and filled the WH back up.
Old 04-27-2016, 06:49 AM   #16
I think I understand what I need to do now. Next time I'm off work I will swap that valve the other way and should work just fine👍. Thank you all for the help.
Old 04-27-2016, 06:52 AM   #17
wmtire's Avatar
I think I understand what I need to do now. Next time I'm off work I will swap that valve the other way and should work just fine��. Thank you all for the help.
You shouldn't have to switch anything, and are making it harder than it has to be.
As stated, just turn the valve handle to the left...and this closes the bypass line and opens up the feed to the water heater. Now go outside and flip up the pressure relief valve on the face of the water heater and water should flow out once the water heater fills up.
Let me see if I can find an internal schematic of how the valve is made so you see how the water flows inside it from the two positions.
Old 04-27-2016, 07:28 AM   #18
Pickin' & Campin'
Originally Posted by rmac04401
Valve looks turned off in pic not letting water flow into tank. I think it should be facing right. Right now it looks like water would flow up to valve then go up to top and go back to your faucet. Looks like your missing a couple of valves for a good bypass setup.
Originally Posted by RSchleder
From the picture, I agree--it sure looks like you need 2 more valves to have a properly setup HW bi-pass system. A valve on the bi-pass tube and a second on on the outlet junction (at the top) is needed to properly divert the water into or away from the water heater.
Please understand that not all water heaters have a three valve, bypass system.
The OP's single valve system is commonly used throughout the industry.
The single valve performs the function of two of the valves on a three valve system.
It shuts off the flow to the cold inlet AND opens the port that feeds the bypass line all in a single turn of the valve. The hot outlet port of the water heater has a check valve built into it that allows water out of the tank but not back in through itself.
A two valve system is very similar except the 2nd valve simply takes place of the hot outlet check valve.
Days Camped: '15=22 '16=46 '17=30 '18=13
Old 04-27-2016, 08:18 AM   #19
wmtire's Avatar
OK, I am confused by this. If you flipped the pressure relief valve and no water came out, then it means you have no water pressure going into the water heater.... and this would happen if you have the valve open to the bypass line (and closed to the water inlet).....and could happen if the water heater had water or didn't have water in it.
Pulling the anode does drain the Suburban brand water heater.
Now here is where it is confusing, as since it appears you have the valve set to bypass the water heater (and stated no water came out of the pressure relief valve)......how exactly did you fill the water heater back up?
What exactly are you connected to, in order to get water to your RV? Are you using the city water supply or the onboard freshwater tank via the pump.
Old 04-27-2016, 11:48 AM   #20
Pickin' & Campin'
wmtire... in post # 8 the op says...
"I may have switched that valve, but I did get the WH full of water."
So I 'think' at some point he did have the valve set to fill the water heater but turned it afterwards.
If he happened to try the pop-off valve after moving the bypass valve to closed, he may not have seen anything come out the pop-off.
Confusing non the less.
heater, water, water heater
