08-18-2018, 06:56 PM
Water heater won’t stay lit
Have a 2004 FR Cherokee, water heater model SW6DE. The gas burner lights but keeps clicking for about 5 seconds then goes out. That happens 3 times then it stops till I flip the switch again. Then the process repeats itself. Trying to figure out if this could be an issue with a specific part I can replace or if I may need to replace the whole water heater. Any suggestions? Thanks in advance for your help.
08-18-2018, 07:03 PM
Are you saying after the propane lights, the direct spark ignitor/DSI keeps making sparks (this is the clicking sound you are hearing)...or are you just hearing the DSI making the sparks, but the propane never ignites really?
There can be several causes (flame sensor, module board, dsi), but we need detailed information to troubleshoot.
2011 Flagstaff 831 RLBSS
08-20-2018, 07:58 AM
The burner lights
The ignition starts clicking, the gas burner lights and I can see the flames going while there is still clicking going on. When the clicking stops, the flame from the burner stops as well. It waits a couple seconds, the clicking starts, the burner lights up, there are flames while it clicks and when the clicking stops the burner goes out. That all repeats one more time.
So, it seems to be lighting fine. It just does not stay lit. Thanks for your response!
08-20-2018, 08:19 AM
We had this problem and it was the module board.
08-20-2018, 08:45 AM
Just as confused as you
The flame sensor may not be detecting the lit burner. My SW6DE lights up on the first try and the clicking of the DSI stops then the DSI Fault lite goes out. It may be the igniter/flame sensor is out of adjustment or a problem with your control board. There is a service manual in the Library section on this forum. Forest River Forums - Downloads - WH_Service and Training Manual 05-18-11.pdf
Richard & Jill
08-20-2018, 02:37 PM
X 2
Steve & Cody the Wonder Dog (he wonders if he is a dog or not)
Forest River - Rockwood
2018 Ultra Lite 2040WS 5th wh
2020 Ram 1500 Eco Diesel Curt Hitch - 392 rear end
08-20-2018, 02:41 PM
Had the same issue, mine was a bad board as well.
2019 Silverado 1500
No camper, currently
08-20-2018, 09:17 PM
x4....Just went thru this with my Georgetown. Bought a Dinosaur Board.
Jaye (Mn)
Jaye & Cindy
2007 Georgetown 349 XL
08-20-2018, 09:35 PM
Mine does this at the start of every outing. It will eventually settle down and work normally. In my case, I think the propane line is empty when I first turn on the propane bottle. It takes a little while for the line to purge itself of air. Same thing with the stove.
08-20-2018, 10:11 PM
I'm having the same issue which started 2 months ago. I thought I fixed it by cleaning the electrode with some fine sandpaper, regapping it, and ensuring that there was no rust flakes, crud such as cobwebs in the venturi pipe. It worked for a bit then started the hard start again.
What is weird is that I can use a lighter to start the flame and the hot water heater works fine for a while until the next morning when I need hot water. My control board is good I think because I can hear and see the spark at night. I'm thinking that the high altitude may be an issue but I've never had this problem before until now.
If you figure out your problem, please let us know. Thank you.
08-21-2018, 08:48 AM
First try cleaning the flame sensor,,, and make sure it is inline with the flame !!!
08-21-2018, 09:07 AM
and before you reinstall it, wire brush the bracket on the flame sensor and the stud, nut and burner tube it mounts on. You need a good ground connection here. If you did all that and it still gives you problems it's probably dinosaur board time
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
08-21-2018, 09:49 AM
After you have tried the above...and Before you by the 'board' ....
Check the gas line . "Gas Off of course" You will see the gas line has a brass fitting on the end with a 'very small' hole in the tip.
Take the fitting off and check it for any debris and also vacuum out the pipe.
The hole in the end fitting is so small that the tiniest speck will clog or impede the gas flow....
Sometimes allowing just enough gas to flow for lighting then goes out.
Yours may be a different type of end fitting... but most have the 'small pin-hole' where the gas comes out pointing into the burner tube.
This is what worked for me with the same indications you talked about.
PS When I took the tube off and tapped it on a piece of paper towel all sorts of scale debris and fine particles fell out.
Good luck
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~ Trail Air - Tri Glide Pin Box 2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles Edge programmer, 4" SS exhaust turbo/back, Tru-Cool Max Trans Cooler, Bilstein Shocks Vancouver Island, B.C., Canada
08-21-2018, 09:53 AM
Not sure if I still have them,,, but I used have a Orfus drill set ???
08-21-2018, 10:26 AM
I don't think I would ever go that route or recommend anyone to do that. If anything blow it out with compressed air from the opposite direction. If you are just bound and determined to stuff something in that orifice to verify clarity, how about a piece of monofilament fishing line? Don't damage a jet
14K Equalizer
08-22-2018, 08:31 AM
Good Luck with the fishing line !!!
08-28-2018, 06:49 PM
I have a 2011 Forest River 5th wheel with a Suburban SW6DE water heater. Previous owner said it wouldn’t stay lit off and on, same for me constantly trying to light . I put in a new dinosaur board and still the same. The FIX is to pull the spark electrode off of the gas tube, then take two pair of pliers and bend the ends of the electrode inward toward the tube mouth maybe and 1/8 of an inch! Has worked every day since. Be sure and bend both ends equally!
