Old 04-14-2013, 06:55 PM   #11
TURBS's Avatar
Originally Posted by Cheesehead View Post
The curds were delicious!
I bet........
Grilled curds.... my fav!
Old 04-14-2013, 07:08 PM   #12
Thanks all for your help. We may have gotten lucky the electric heater has provided hot water. The gas burner hasn't lit but at least we have hot water and it appears I didn't burn out the coil!
Cheesehead is offline   Reply With Quote
Old 04-14-2013, 07:22 PM   #13
wmtire's Avatar
Cheesehead (sorry but I can't quit laughing at your nickname), can you tell us the exact steps you are taking to light the propane side of your hot water heater.....including what switches you are turning on?
Also, is anything else working off of propane...ie stove, heater?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 04-14-2013, 07:28 PM   #14
Originally Posted by f1100turbo View Post
I bet........
Someone from WI better bring a bunch of curds, I'd like to buy some! Love 'em.
Old 04-14-2013, 07:29 PM   #15
VinceU's Avatar
Don't forget to check your 12 volt fuses, one is for the water heater in the central electric fuse and circuit breaker control panel.
Old 04-14-2013, 07:40 PM   #16
caper's Avatar
If the water is hot from electric side propane will not come on.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-14-2013, 07:45 PM   #17
Does the system run on electric when you are plugged in and only use propane when there is no electric. I am very uninformed.
Old 04-14-2013, 08:01 PM   #18
wmtire's Avatar
If you have a dual-powered water heater, it can run off of electricity (when available), propane....... or both at the same time.
You have to turn the propane and electric sources on. There may be an inside switch for the propane, and an outside switch for the electric. There could also be TWO inside switches, one for propane, and one for electric. That's what is bad, as Forest River doesn't make all the trailers the same way in this process.
That's why I was asking the steps you are taking. As Caper pointed out, if the water is hot from the electric heater element, then propane has no reason to come on. You can actually leave both switches (propane and electric) on, then if you use a lot of hot water faster than the electric heating element can keep up, then the propane will ALSO fire up and heat the water. Propane is always quicker than electric.
If you have the Suburban dual powered water heater, here is a more detailed explanation:
http://www.forestriverforums.com/for...tml#post327989
Old 04-14-2013, 08:02 PM   #19
VinceU's Avatar
Electric element works only with shorepower or generator.
Gas heater works with or without the electric heater, but as Caper says only when water is not hot already.
Old 04-14-2013, 08:41 PM   #20
wmtire, I was only turning the water heater switch on in the coach. I also made sure the switch outside where the water heater is was on. I think the problem was that the water by pass was not closed. Luckily I had the valves to the heater open also and didn't burn up the coil. Since the water was hot the gas burner didn't lite. So much to learn but thanks to you all we now have hot water.
