Old 04-14-2013, 04:44 PM   #1
Water heater won't light
First time out with our new Rockwood mini lite 2306 and hot water heater won't light. Electric doesn't heat water either. Any help greatly appreciated.
Cheesehead is offline   Reply With Quote
Old 04-14-2013, 04:52 PM   #2
TURBS's Avatar
Is there even water in the tank?
Can you hear the propane side working?
Did you turn the by pass valves?
Old 04-14-2013, 04:54 PM   #3
TURBS's Avatar
Winter position
Summer position
Old 04-14-2013, 05:04 PM   #4
I think there is water in the tank. When I dewinterized it I forgot to put the "rod" in the tank and water started running out the hole. Can't see the valves very well but I think I have them opened correctly. I will check again.
Old 04-14-2013, 05:06 PM   #5
Herk7769's Avatar
Open the pressure relief valve. If air gushes out you had the top valve closed (or check valve is stuck closed) ; if so you most likely burned out the 120 volt element.
HAM CALLSIGN - KC3FFW
Old 04-14-2013, 05:11 PM   #6
Herk, you may be correct. Even so, won't the gas burner come on?
Old 04-14-2013, 05:17 PM   #7
Herk7769's Avatar
The gas system is completely different than the AC heater system.
However the common thread is "water in the tank."
Without water in the tank, the over temp thermostat could pop. This prevents power from going to the control board.
Make SURE the tank is full and the valves are properly positioned.
Make sure the outside AC switch and the inside DC/Gas switches are OFF.
Open the outside cover and press BOTH overheat reset buttons.
If they reset; you should be "Good to Go."
If one or the other system does not work, check back for some other things to check.
The over heat reset is under the rubber circles.
Name:	AC diagram.jpg
ID:	27959   Click image for larger version
ID:	27960   Click image for larger version
Name:	waterheater reset buttons.jpg
Old 04-14-2013, 05:31 PM   #8
I will check the things you mentioned. We are in middle of fixing dinner so will work on it later. Thanks again for the help.
Old 04-14-2013, 05:32 PM   #9
TURBS's Avatar
Cheese curds? Lol
Old 04-14-2013, 06:54 PM   #10
The curds were delicious!
