Old 04-25-2012, 09:26 PM   #1
Unruly's Avatar
Water Hose Entry Elbow
Hello, does anyone use a Water Hose Entry Elbow? I purchased one thinking the product seemed like a good idea. When I opened the package a got a good look at it, the inside diameter gets very small. I am wondering about water flow restriction and limiting gph? any feedback on this would be appreciated.....
Bill and Sarah
Edinboro Pa
2008 F350 Lariat Crew Cab Diesel DRW 4X4
2012 Sabre 34REQS
Unruly is offline   Reply With Quote
Old 04-25-2012, 09:41 PM   #2
pbrackney's Avatar
I just purchased one as well but have not used it. I would love to hear about experiences with it as well.
Philip, DW, 3 DD, 1 DS, and Ginger our Dog
2017 Wildwood 30QBSS
2003 Ford Expedition 5.4 Liter with 3.73 Axle
Equalizer 4-Point Sway 12000# & Tekonsha P3
pbrackney is offline   Reply With Quote
Old 04-25-2012, 09:47 PM   #3
Put those suckers in a vice and with a variable speed drill motor and a 3/8 drill bit, ream it out. End of problem.
Old 04-25-2012, 10:09 PM   #4
Steve7575's Avatar
I've used one for many years. Never had a problem with water flow. it decreases the stress on the fitting of the trailer. Also makes the supply hose snug closer to the trailer.
Steve7575 is offline   Reply With Quote
Old 04-25-2012, 10:47 PM   #5
J. Parham
snjparham's Avatar
Been using an elbow since we started RVing 3 years ago. Never any problems.
2011 8528BHSS
2013 Silverado 2500HD 6.6L
Nights Camped in 2011: 32
Nights Camped in 2012: 85
snjparham is offline   Reply With Quote
Old 04-26-2012, 05:46 AM   #6
member
We have used one since we owned aT T. Never had any issues .Never checked the hole size though.But I will to see what it looks like. Maybe we can improve it ?
2019 Cedar Creek Silverback 31IKS
2017 F 250 6.2 gas 4.30 8' bed
HIDE OUT is offline   Reply With Quote
Old 04-26-2012, 08:27 PM   #7
Been using an elbow for 8 years on 3 different campers with no problems. As Steve7575 said, they do reduce the stress on the city water hookup.
Old 04-26-2012, 08:39 PM   #8
I have been using one for many years, think of this if the hose is connected it still has to make a 90, or a bend, which will restrict the flow as well, an elbow hos less of a restriction and assures adequate flow. 90 degree sweeps are common, actually standard, on fire apparatus because they reduce the friction loss..vs hose crimping.
The elbow also prevents wear on the hose.
Bill M
2012 Georgetown XL 360
2011 Chevy Equinox - 2006 Chevy Avalanche
Bill m is offline   Reply With Quote
Old 04-26-2012, 10:02 PM   #9
Fire Instructor's Avatar
I use one all of the time. The friction loss of a somewhat narrowed passage over such a short distance is negligable. And since the metal elbow is smooth, compared to the inside of a rubber hose, it's even less of an impact.
The elbow takes strain off of the connection and the hose. It also keeps the hose close to the side of the TT, minimzing opportunity for someone to brush against it, and damage it.
Fire Instructor
2022 Coachmen Leprechaun 319MB
2022 Ford Ranger toad
Fire Instructor is offline   Reply With Quote
Old 05-02-2012, 09:56 AM   #10
Thurman's Avatar
I use one mainly to keep the hose close to the camper. I also believe that one takes the stress off of the connection of the camper. Mine is a brass type in which the bore is the same all the way through. I have seen some plastic ones in which the bore decreases at the elbow. This is designed to give strength at the elbow, but does reduce water flow to a point although I agree it would be negligible.
Thurman is offline   Reply With Quote
Old 05-02-2012, 10:43 AM   #11
Tee
Tee's Avatar
I made my own out of Copper. Has a full 3/4" flow and long radius 90. Never used it though as we are always were there are no water hookups?!?!?
Tee is offline   Reply With Quote
