Old 04-01-2019, 07:10 PM   #1
Mark S.'s Avatar
Water in storage
We have a 2018 Salem Hemisphere. While towing in a pouring down rain, my wife noticed water in the middle of the storage area the next day . Only one box was wet. This is under the drain of the sink in bath. We ran water and even filed the tub with water , no water leaks. Insulation is dry also. No other signs of moisture. Has anyone had a issues like this ?
Mark S. is offline   Reply With Quote
Old 04-01-2019, 08:05 PM   #2
I cant explain it, but I did have something similar. The cause was the shower waterless trap wasn't connected well. I reconnected it, made sure a connections were tight and the problem no longer occurred.
Hooe that helps.
Skip12 is offline   Reply With Quote
Old 04-03-2019, 08:45 PM   #3
Water can easily get into storage area while traveling in rain. The storage doors are not air tight so as the tires sling water up it could have gotten into your storage area or just traveling,wind could have caused a gap in the storage door and let the rain in. Just a thought.
happyttowner is online now   Reply With Quote
storage, water
