Water inlet
I will probably set off a firestorm as I did on a FB page, but here I go. We have the Cedar Creek 38DBRK. It has 2 black tanks, so it has 2 flush lines. It also has the 1 inlet for the potable water and you select by valve if you want water to go to the tank or to the system. To keep from having the pain of closing the faucet valve from campground, bleeding pressure off and then re-connecting, I made a manifold with valves, so that I only have to connect the hose when arriving to campground and disconnecting when we leave. I posted this on the FB page and here came the plumbers that do it for a living, saying the flush lines would siphon back into the lines. My thinking was if that was possible, it would happen just hooking your garden hose up directly to the flush connections. What's y'all's thoughts on this.
2020 Cedar Creek 38DBRK 5'r
2020 Chevy 2500HD Duramax 4X4
