05-05-2018, 03:37 PM
Water inlet 90 degree elbow
Newbie question alert!! [emoji16]
What is the proper protocol for the 90 degree elbow for the city water inlet - do y’all keep it on there all the time or remove each time you leave the camp ground? Seems to me the plastic inlet would wear easily with constant attach/detach of water hose.
05-05-2018, 03:55 PM
I remove it. Been using it for 2 yrs, no wear yet. Would be no different if you were connecting the water hose directly to the inlet without the elbow.
Bill and Gail
2016 Sunseeker 3010DS
V10 6 speed transmission
2017 Ford Fiesta toad
05-05-2018, 05:15 PM
We used one on our tt for almost 4 years with no problem til we changed rigs.
Always removed it before traveling.
2015 Dynamax REV 24TB class C
05-05-2018, 05:43 PM
I have always removed it. No problem.
05-05-2018, 06:14 PM
Remove it. The guy behind you may not be happy if it vibrates off.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
05-05-2018, 07:48 PM
Jeff
I have also always removed it - goes in the tote with the splitter, water regulator, water filter, etc. part of the routine
Jeff & Peggy
2019 Coachmen Mirada 35BH
Avid campers since 1999
05-06-2018, 01:21 PM
Leave it on
I always leave it on. One less thing to worry about. Never had it vibrate loose l
05-06-2018, 01:39 PM
Take it off and cap the connection per design.
If you leave it on, I'd suggest you buy a cap for it.
2011 Traverse LT, 3.6L, FWD
05-06-2018, 09:02 PM
New to FR. Old to TT
I have put quick connect fittings on the water in let and a different style one on the black tank rinse. then use a chair leg rubber foot to cover the open end when not hooked up makes fast work of setup and not messing with the hose threads.
2018 GMC 2500 Denali HD ,Duramax with Allison trans.
2019 Cedar Creek 36ck2
05-07-2018, 04:20 AM
Our plastic inlet has a rubber plug. It works as well on the inlet side of the 90 as it did on the plastic. I see no reason to remove mine.
It comes off for one reason, once a year. So I can screw on a brass fitting that lets me use compressed air to remove winterize the camper.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
05-07-2018, 06:17 AM
The place we bought our camper from purposely put the spare tire in the front of the water inlet so they could sell us a 90 for city water. I told them to move the spare tire. Problem solved.
05-07-2018, 06:33 AM
our water inlet is inside the exterior door on the left side where the dump valves and outside shower are located.
The hose inlet is on the bottom so the hose is coming straight up to an inlet that is horizontal. The 90 degree fitting is not required but VERY handy.
05-07-2018, 09:52 AM
I think WHERE it's located is also an issue. If yours is inside a "docking station" or bay, that's a different situation than if it's hanging out of the side the rig, as mine would be.
05-07-2018, 09:55 AM
Agreed, but on my previous camper, where it was outside, I didn't use one at all.
I didnt see a need for it
05-07-2018, 10:05 AM
I use mine because 1) it puts less strain on the water connection and 2) it allows me to coil the excess hose under the TT so things look neater.
05-07-2018, 10:17 AM
Ours i son the back side of the camper. I only look there when setting up and when loading to come home, don't pay much attention to neatness there.
In the side we live on, I pay close attention though.
05-07-2018, 11:12 AM
Retired and Loving Life!
I remove mine and have had no problem. Same difference as attaching s hose every time with out it I figure.
05-08-2018, 09:44 AM
Thanks for all the replies! I’ll just remove it each time.
