Old 01-22-2019, 12:43 PM   #1
Don
2011George.360's Avatar
Water Inlet & Dump Valve
Hi from sunny Florida. We have a 2011 Georgetown Ds360 XL and love it. Very few minor issues (except for the peeling furniture).
It is time to replace the black tank flush inlet check valve and need to know what size to get - 1/2 inlet to 3/4 outlet ?
And when draining the grey tank, the black tank drain valve leaks ( suspect black tank drain outlet flange is cracked). Is it a 3 inch valve ?
Thanks for your thoughts.Click image for larger version
ID:	195144Click image for larger version
2011George.360 is offline   Reply With Quote
Old 01-22-2019, 01:12 PM   #2
bubbles's Avatar
That flush port will not be a check valve just an inlet for the hose connection. The check valve is somewhere inside your coach in line with that port tubing and the tubing to the black tank. Pull the 3 screws and take a look see at what you need.
Old 01-22-2019, 01:15 PM   #3
bubbles's Avatar
By the way, why are you replacing it. It's not a time change item.
Old 01-22-2019, 01:33 PM   #4
Don
Thanks for your quick reply. During a flush attempt, I don't hear any water entering the black tank. I once had the same issue with my fresh water tank and the dealer repaired it under warranty. They said it was the inlet valve/check valve. So, I assumed I had the same issue. I know- Assume...
Old 01-22-2019, 01:34 PM   #5
Don
And- is it a 3 in drain valve?
Old 01-22-2019, 01:48 PM   #6
bubbles's Avatar
I'm thinking you might have a clogged nozzle at the black tank. Yes, your holding tank input port has an integral check valve. I'm not sure where your black tank vacuum breaker-check valve is within your coach. Mine is in the washer/dryer closet and some are under the bathroom vanity (it will be above the height of your toilet rim wherever it is). Here are pictures of the type typically installed by Forest River. I don't know how to gain access to your units black tank cleanout nozzle. Mine is through the water heater and a PIA to get at.
Name:	vacuum-breaker black.jpg
ID:	195152   Click image for larger version
Name:	vacuum-breaker clear.jpg
Old 01-22-2019, 01:55 PM   #7
bubbles's Avatar
The tank drain valves themselves are not difficult to change (4 bolts/washers/nuts) but where they are located is sometimes the killer. Typically the black tank drain valve is 3" while the grey is 2". I did say typically.
Old 01-22-2019, 02:01 PM   #8
bubbles's Avatar
Here is a typical Georgetown black tank cleanout system installation.
Name:	black tank cleanout1.jpg
Old 01-22-2019, 02:52 PM   #9
Don
Thanks Bubbles. Much appreciate the feedback and drawing. I'll take off the inlet tomorrow and see exactly how it is constructed. Afterward, I'll search for the vacuum breaker. Having 2 black tanks, I should find 2 ...lol.
Old 01-22-2019, 02:55 PM   #10
Don
I'll trust your instincts and order the 3 inch drain valve.
valve, water
