Hello everyone, I'm new to the forum and my camper, I have a salem le 28bh 2005, the problem I have, is that not provide hot water in the taps, step outside and palp what I understand is the heater is hot . I do not have the manual trailer. thanks for the help
Your winter bypass is probably still turned on. Located on the rear of the water heater, you will neede to turn the bypass valve off. Other posters will soon follow up with pictures and illustrations. Stay tuned.
The line that runs between the hot and cold water lines needs be turned off. Generally, the valve needs to perpendicular to the line, and the valves to the water lines into and out of the water heater need to be parallel to the lines.
