Old 10-30-2017, 08:39 PM   #1
Water Issues!
I have a 2015 Forest River Surveyor 32rlts. Hooked up the water to the city connection and after about 2 hours I noticed water leaking from under the camper. It had crossed over somehow to the fresh water tank and was over flowing. I have never even used the fresh water tank. Always used city hook up at campgrounds. I can not find a valve anywhere that may of been bumped open accidentally. Does anyone have any ideas or a water schematic for this particular camper? TIA!
Aquanet is offline   Reply With Quote
Old 10-30-2017, 08:47 PM   #2
likely the check valve in the water pump got stuck open. I have seen many posts this year with the exact same problem. I am not sure but, I think the remedy is to turn off the city water, relieve the pressure of the system and either adjust the pressure switch on the pump (set screw), or open up the filter screen housing on the pump and hope that the check valve springs back into proper position.
Good luck.
slimetime is offline   Reply With Quote
Old 10-30-2017, 08:47 PM   #3
Scoundrel
HangDiver's Avatar
Common problem when the check valve on the water pump doesn't seat properly. Cut off the water supply from your City water connection. Turn on your water pump and run a faucet or two for about a minute. Turn off water pump and reconnect to city water - that should reset the valve.
Good luck.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 10-30-2017, 08:49 PM   #4
rracer5's Avatar
Good luck.
X2
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
water
