Originally Posted by Beckylamp
We have checked the drain also! The dealer we bought it from is no help at all! We are beyond aggravated! Thank you for telling me Lexel! The only time it leaks is after you shower. We check it daily. We will get up on the roof and check for cracks! Thank you!
Well you need to be checking the shower more closely then.
Cracks in the shower pan are not unheard of (and often only seen when standing in the shower) and water can easily run behind the spigots controls or a screw head.
Best of luck finding it and sorry to hear about your dealer.
Often times finding a good dealer is as important as the purchase itself.
Mobile techs can work on warranty issues as well. Maybe find a good one in your area. Good ones are usually are capable of handling warranty claims.
DO NOT use Lexel or ProFlex RV on the roof.
That is a job for Dicor self leveling sealant or Super Flex sealant if you have an Alpha TPO roof.
