Old 07-18-2015, 11:54 AM   #1
water leak?
I have a 2015 Rockwood 2703ws. Several hours after connecting to water supply, my fresh water tank showed full(it started with 1/2 tank) and water was leaking out of the fresh water tank fill spout. Pressure wasn't any more than normal and this was in the middle of a 30 day trip with no other complications before or since. Any ideas?
padgie945 is offline   Reply With Quote
Old 07-18-2015, 09:13 PM   #2
Sounds like water is backing through your water pump.
dmac1951 is offline   Reply With Quote
Old 07-18-2015, 09:19 PM   #3
bikendan's Avatar
Bad check valve?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-18-2015, 11:00 PM   #4
Thanks. I found the same question in another post. A check valve sounds rivht and there was a procedure to try to fix it, just probably dticking a little.
leak, water, water leak
