Old 12-09-2014, 08:23 AM   #11
Originally Posted by jimex View Post
...I disconnected the flex tube from the toilet flush valve to drain the flush valve. This was all reconnected prior to restart. I also removed the filter element. We decided to leave it out until next spring when we start camping again. All that is tight and leak free.
I would suspect you did not get the flex tube threaded correctly when you re-connected it or it's not tight.
Old 12-09-2014, 08:50 AM   #12
Old coot - the leak is behind the wall. Not at the fitting.
jimex is offline   Reply With Quote
Old 12-09-2014, 04:26 PM   #13
Found the leak. A pinhole leak caused by a staple. The staple came out of the flexible tubing hose when I drained the toilet hose and valve. I used a coupling. A pretty easy fix. I started to use Pex, but I would have had to change out multiple fittings to switch over and the work area was very tight, so I found a coupling that seems to work just fine. Thanks for all the feedback.
Old 12-09-2014, 08:00 PM   #14
WFD
Just keep a close eye on it for a few days...I thought I had mine licked too, then after a couple days the bulge in the outer jacket happened and it started leaking again....hope that won't be the case for you but just keep an eye on it to make sure.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
leak, water, water leak
