Old 07-01-2015, 03:06 PM   #1
Water leak from shower?
Hello all, we were camping in our Wildcat Max 313RE this past weekend. My son was taking a shower and I had to go get something out of the outside front storage area. When I opened the door I noticed water dripping down the right side panel forward of the shower. After watching it for a couple days I narrowed it down to only when someone is taking a shower does it leak. It's not a huge leak, I can stuff a paper towel up where the water is coming from and it will soak it up. It's right near a water line, but I can't see any leaks from the lines. I know I need to find the leak before any major damage happens! Any ideas?
atcla is offline   Reply With Quote
Old 07-15-2015, 09:55 PM   #2
Found the leak, the water was getting through the silicon at the rear of the shower!
Old 07-15-2015, 10:52 PM   #3
jtstromsburg's Avatar
interesting find. My brand new Sabre has a similar leak that I haven't been able to track down yet. I thought it was the shower door leaking, so dismantled the frame and bottom rail, cleaned it all up, added lexan, and re-installed everything, finishing with a bead of lexan inside the bottom rail. Still leaks. Like you, I find water in the drivers storage bay, but also the bedroom carpet is damp so it's weeping a ways.
So when you say rear of shower, do you mean a seam? My shower is a residential style, so shouldn't leak.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is offline   Reply With Quote
Old 07-16-2015, 11:31 PM   #4
Yes, I think it's coming from the seam at bottom. It looks like water is getting under the caulking. I put a washcloth where I think it's leaking and it stopped running down into the storage bay. I hope you get yours figure out, sounds like you rebuilt your shower!
leak, show, shower, water, water leak
