Water leak from under tub Clipper 17BH
Hope this will be helpful to others: we have a 2016 Clipper 17BH, bought used last year. Taken out several times & have had an intermittent water leak in bathroom on floor between toilet & tub, not a constant leak but more like a puddle showing up. Check & checked & found no source. Finally around Halloween we stayed set-up for 2 weeks & leak reappeared. Got to checking & DW realized that leak would only appear after restarting hot water heater. Pulled tub side panel & found 2 water stub-offs (hot & cold) capped under tub & the hot stub would leak during water heat up. Capped off stubs look like maybe a standard tie-point for an outside shower????? not sure. Tightened plug & no more leak. Pictures attached (I hope) will make it more understandable.
