Old 07-12-2018, 07:26 AM   #1
Water Leak Inside
Good Morning,
Our Flagstaff Classic travel trailer (2012) is leaking inside. When the water is turned on there is a leak in the back room coming from under the bunk bed. The floor feels a bit mushy in that part of the room as well. (Maybe it has been leaking for awhile?) It also leaks from wall by the toilet if the water is left on too long. This has never happened before and we don't know where to begin looking for the problem. Does anyone have ideas? We appreciate it.
KellyC is offline   Reply With Quote
Old 07-12-2018, 07:45 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. When you say turn the water on are you talking city water or your FW pump? makes a difference in solving the problem.
Retired Navy
2016 Flagstaff 26 FKWS
Old 07-12-2018, 07:48 AM   #3
Water Leak
Thanks for the reply! It's the city water.
Old 07-12-2018, 07:58 AM   #4
Coach
It's likely just a break in your water line, but it needs to be found and repaired. Start with removing any panels near your wet areas and work your way out from there. If you live in colder regions, it's pretty easy to miss a spigot when you're winterizing that can freeze and crack. Any water fixtures in the areas inside or out?
Cut it 3 times and it's still too short...
2017 Sandpiper 381RBOK
2006 Ram 3500 Cummins Dually
valleyduo is offline   Reply With Quote
Old 07-12-2018, 08:03 AM   #5
Yeah, we live in Ohio so the winterizing is probably the issue. The kitchen sink faucet blew when we first camped this summer. So, there are no panels near the wet areas. I think we will need to cut the floor? Seems drastic but we don't know how else to see the issue. Could we see it underneath the camper? If the issue is in another area, not directly near where the leak is I wonder if that would cause the same issue.
Old 07-12-2018, 09:00 AM   #6
Wellp, we figured it out. Kind of embarrassing but good news. All we did was put the regulator on the hose...no more leaks! Thanks for the responses. Now we are off to deal with installing new faucets.
Old 07-12-2018, 09:19 AM   #7
FWIW......I'm not sure why a "Regulator" would "Cure" a leak.....
Unencumbered By The Thought Process
tande is offline   Reply With Quote
Old 07-12-2018, 11:26 AM   #8
Ok. New problem. We replaced the kitchen faucet and now it is leaking where the hot water hose attaches. Are there special connectors we should buy? Thanks!
Old 07-12-2018, 12:47 PM   #9
Might help to post pictures of where the actual leak is
dafoot2 is offline   Reply With Quote
Old 07-12-2018, 01:06 PM   #10
It's under the sink..in a really tough spot to reach. It's where the hot water hose attaches to the sink. We got the cold water attached but it's like the hot water one just does not fit. No matter how many times we try it just leaks...
Old 07-12-2018, 01:32 PM   #11
ben31's Avatar
Did you use Teflon Pipe-Thread Sealant or Teflon Tape?
How badly is it leaking? If only an occasional drip, and you didn't use one of the above, try that. If it is streaming out, one of two things to check:
1. Are you getting the connector on correctly (straight on the threads)? If not, try to line it up better.
2. The threads may be stripped. If so, you'll need ascertain whether it is stripped at the faucet or at the hose connector and replace the offending component.
Past that, without being there or seeing it, it may be pretty hard for us to help out.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
Old 07-12-2018, 01:56 PM   #12
rk06382's Avatar
I always wanted to use that.
I had a leak last week. My wife left some water in the sink. I had to replace the gaskets in the sink strainers. What a mess.....
Back to OPs leak:
When I replaced the original kitchen faucet. I had to add a pex valves to connect to the new kitchen faucet lines.
Pex before.
Name:	20170706_192354 Crop before Sink.jpg
Pex After new kitchen faucet:
Name:	20180707_171055 Crop valves.jpg
I took the plywood deck out to dry the leak.
New kitchen faucet:
Robert
2018 FR3 28DS | Boondock 99% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks | RVLock
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 07-12-2018, 02:31 PM   #13
Thanks!
1. We wondered if the threads were stripped...but it is brand new.
2. We understand that it has to match up perfectly but that seems to be the issue...once we start screwing it on a gap forms and we cannot get rid of it. Feels like we've tried a hundred times.
3. This is the second time we have installed a sink here...it was a challenge the first time due to the space but not this difficult.
Here is a horrible picture, hard to get a good one - the space is ridiculously small.
Thanks for the info - such a helpful group!We will keep investigating.
leak, water, water leak
