Originally Posted by KellyC
It's under the sink..in a really tough spot to reach. It's where the hot water hose attaches to the sink. We got the cold water attached but it's like the hot water one just does not fit. No matter how many times we try it just leaks...
Did you use Teflon Pipe-Thread Sealant or Teflon Tape?
How badly is it leaking? If only an occasional drip, and you didn't use one of the above, try that. If it is streaming out, one of two things to check:
1. Are you getting the connector on correctly (straight on the threads)? If not, try to line it up better.
2. The threads may be stripped. If so, you'll need ascertain whether it is stripped at the faucet or at the hose connector and replace the offending component.
Past that, without being there or seeing it, it may be pretty hard for us to help out.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
