Old 01-19-2018, 08:42 PM   #1
Calsiera's Avatar
Water leak to washer
I believe I have a leak in the pipe going to the washer in my bedroom closet. There is water dripping outside from inside where the fifth wheel hitch comes out from the bottom front of the rv. Also, the floor on that side of my bedroom squeaks.
Has anyone else had this happen to them? How can I tell?
Thanks!
Calsiera is offline   Reply With Quote
Old 01-19-2018, 08:50 PM   #2
cavie's Avatar
Thanks!
Find that leak ASAP. Pressboard wood (flooring) does not play well with water. Pull the washer out of its hole and inspect the floor.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 01-19-2018, 09:24 PM   #3
Calsiera's Avatar
The floor in the closet feels dry. The hookup does not leak. I'm afraid it is under the floor wherever the pipe comes to the spot it comes up to the washer... between the insulation and flooring, maybe?
Calsiera
2017 Sierra 371 REHB
43 ft. Fifth Wheel
Old 01-19-2018, 09:34 PM   #4
Was the unit winterized? If so, was pink RV antifreeze used? Is the water you see dripping clear?
If your floor squeak was because of a leak, your carpet would be wet also.
You could have a leak around your front cap or on the roof that would leak out at the hitch area, or you may have a clearance light leaking. Has it rained lately?
Travel safe
2001 Ford F-350 Super Duty CC Dually, 7.3 Diesel
2011 Cedar Creek 36CKTS Touring Edition
FordHauler is offline   Reply With Quote
Old 01-19-2018, 09:51 PM   #5
cavie's Avatar
If the leak is under the floor your ok. can you open the underbelly?? If your seeing a drip I'm guessing it's at a seam?
Old 01-19-2018, 09:56 PM   #6
Calsiera's Avatar
I live in it. Yes, it rained yesterday and last night. The water is clear.
My rv is a 43 ft. 2017 fifth wheel. I wouldn't think it would have these problems. It has moved only once.
If it is a clearance light leaking would the water travel like this and come out from under the bedroom?
Thanks for all the ideas! If I have to take it in, I need to hire someone. Then I'm out of my home, too.
Calsiera
43 ft. Fifth Wheel
Old 01-19-2018, 10:07 PM   #7
If the leaking clearance light is one of those in the front cap, yes that is possible.
Since you live in the unit talk to Forest River about a mobile tech doing the repair.
You should be able to prove or rule out the washer hose leak by turning off the campground water supply and turning on your water pump. If it builds pressure and turns off and stays off for 5-10 minutes then I would say you have no leak to the washer.
Travel safe
Old 01-19-2018, 10:35 PM   #8
Calsiera's Avatar
Thank you so much for your help. I will do this tomorrow. Hopefully., they can send one out soon. We are finally getting into the winter mode here in northern California and I really don't need leaks with snow on the horizon.
Thanks!
Calsiera
43 ft. Fifth Wheel
Old 01-19-2018, 11:17 PM   #9
Fulltime family RVer
I had water leaking out of the front overhang of my fifth wheel. The inside was dry. I believe that I traced it to a spot on the roof that needed more sealant (mine was 5 years old, though).
A newer camper doesn't mean a leak free camper.
Are you willing to get onto the roof? You should check everywhere that there is existing sealant and make sure there aren't big cracks or openings in it. Also make sure it's well adhered to the roof. And finally, look for miscellaneous other cuts in the roofing material.
If you can't or won't get on the roof, a mobile RV tech can take care of this for you. Coming from a fellow full-timer, there's no need for you to take this to somewhere and drop it off.
Old 01-19-2018, 11:36 PM   #10
Calsiera's Avatar
Thank you! There is a mobile tech in my area. I can contact him.
Calsiera
43 ft. Fifth Wheel
leak, water, water leak
