Old 05-05-2014, 04:58 PM   #1
Water leak under sink
My hot water is leaking under my sink at the small connections that T into the line going up to the faucet. These lines are held by little connectors that I cant figure out how to tighten up. any ideas would be greatly appreciated. Thank you, Jim
2013 Coachmen Freedom Express 291 QBS
2013 Chevy Silverado 1500 Crew 4x4 5.3
Jandj1026 is offline   Reply With Quote
Old 05-05-2014, 05:26 PM   #2
Iggy's Avatar
They are compression straps and can not be tightened.
Must be replaced with a new strap. Must have the special tool.
Old 05-05-2014, 05:28 PM   #3
Thats kind of what I thought. May just re-do it and use good old hose clamps.Thanks for the reply.
Old 05-05-2014, 10:42 PM   #4
WFD
Dont want to burst your bubble but your regular hose clamp probably wont solve the problem, as your not likely to be able to get to cinch down tight enough on the tee to be leak proof.
WFD is offline   Reply With Quote
leak, water, water leak
