Old 09-19-2016, 08:43 PM   #1
Water leak when filling fresh water tank
I have a 2014 Salem Hemisphere 282RK travel trailer. The fresh water fill is on the back side (driver's side). It is just to the rear of the hot water heater and in line with where the bathroom is located.
I never turn the hose on full. This weekend for the first time while tank was filling, water ran out from the area below the fill valve under the trailer. I know it was not coming from the over flow or tank drain valves. The fill valve on this trailer screws onto the hose so I know it wasn't backflowing up the fill hose.
The underbelly is sealed and a gas line runs under the frame and plastice seal material so opening it up won't be easy.
I read a thread once where someone hsd a similar issue but I couldn't find it.
Any thoughts of where the source is and how to get to it?
Thanks!
Lowes48fan1 is offline   Reply With Quote
Old 09-19-2016, 09:13 PM   #2
KenHwy61's Avatar
You could try removing your freshwater tank gravity fill port and taking a look. Typically attached with three screws. It should pull out a little once the screws are removed. If it pulls all the way out the tubing probably has become unattached at one end or the other. Also the coroplast bottom is not very hard to open. Carefully cut a small 3-sided trap door where you need to access. You can just duct tape it closed or put a more permanent patch over it.
Seasonally in the Grand Marias, MN campground
On the beautiful shores of Lake Superior
Aviator Wright-Flyer#1908
2012 Ram 2500HD CTD
KenHwy61 is online now   Reply With Quote
Old 09-19-2016, 09:14 PM   #3
RSchleder's Avatar
Does the water connector have screws in it attaching it to the trailer. If so, I'd remove the screws, remove any caulk from around the connector and pull to out to see if the hose attached the backside is water tight. Sounds like you could have a loose connection somewhere and that's the easiest place to start looking.
Days camping (2016)----181 days
Days camping (2017) --- 52 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 09-19-2016, 11:26 PM   #4
NMWildcat's Avatar
On my rig the outside fill valve has a long neck that goes inside of the flexible fill tubing that goes to the tank. The joint between the two was just glued. Of course it failed. I took the outside flange off, and it had enough play in the tubing to gain access and repair (with a hose clamp). But they are all different so you will have to explore
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 09-20-2016, 01:45 PM   #5
I had almost exact same issue with my 2016 26RR. Opened base cabinet under bathroom sink, removed lower panel to expose water pump, outside shower connections, heat ducting to bedroom and outside fresh water fill. The hose clamp on the fresh water fill had never been tightened and was also about 4" too long, caused the fill hose to form a goose neck before going down toward the tank. Check there, hope this helps.
extxn is offline   Reply With Quote
Old 09-26-2016, 09:04 AM   #6
Unfortunately it doesn't. The fresh water fill isn't the type where you can insert the fill hose into the opening. On this trailer the fill hose screws onto a garden hose-style fitting. There are no screws or any obviously apparent way to loosen or remove this fitting.
I think I may have to remove the LP gas line and the underbelly cover or cut a hole in the underbelly to try and access the fill line. This is what I was hoping to avoid if possible.
Matt
2013 F150
fresh water, leak, tank, water, water leak, water tank
