Old 10-04-2016, 08:08 AM   #1
Water leak when washing dishes
I own a 2014 317rl. Yesterday I noticed water dripping to left of front door, underneath the carriage when washing dishes. Checked under cabinet and fittings were dry but floor back at wall seam was wet. Any thought on what could be leaking? It appears to be in wall.
Ejwitman is offline   Reply With Quote
Old 10-04-2016, 08:15 AM   #2
SeaDog's Avatar
check the bottom of the faucet and the lines running to it.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 10-04-2016, 11:42 AM   #3
Found problem
The drain system runs from the sink to behind the stove. Took drawer under stove out and there is what I call a gooseneck tee. The bottom socket is broke off. Now my next question since it is a clean break, can I glue it back together?
What glue would you suggest. It will need to set fast since I need to hold it in place. Good news is the way the crack runs it seats easy.
Old 10-04-2016, 04:01 PM   #4
SeaDog's Avatar
I think what you are calling a gooseneck T is what I would refer to as an air gap maybe not in anywise I would not try and glue it together I would install a new fitting.
Retired Navy
AF&AM of Idaho
Old 10-05-2016, 03:25 PM   #5
Closing thread
Thanks SeaDog. I removed the oven, actually very easy. I am going to cut out the three legs to have room to repair tee and reinstall using unions.
leak, water, water leak
