Old 10-19-2018, 11:00 PM   #1
Water leaking at fresh water input
I connected my water hose to my tt 2012 Wildwood DLX for the first time since I bought it and it is leaking water right at the connection. I tried taking it off and back on a couple of times but still leaks. Any suggestions?
Wayne O is offline   Reply With Quote
Old 10-19-2018, 11:10 PM   #2
KeithInUpstateNY's Avatar
First thought is there should be a rubber washer inside the end of the hose. If it is missing ot damaged the connection will leak. Sorry if I am starting the obvious.
KeithInUpstateNY is offline   Reply With Quote
Old 10-19-2018, 11:18 PM   #3
I should have mentioned that I did place a rubber washer inside the connection.
Old 10-19-2018, 11:34 PM   #4
bikendan's Avatar
You don't attach the water hose to the FW tank fill, only to the city water connection and the black tank flush connection.
The FW tank fill is only threaded for the cap, not the male end of a hose.
Unless something has changed.
Equalizer WDH
Old 10-20-2018, 04:46 AM   #5
Sometimes the brass ends on supply hoses are cheaply made and distort easily,if not the hose the shore water supply assembly on the RV can be replaced without much difficulty or money! Youroo! !
Old 10-20-2018, 06:13 AM   #6
It is connected to the city water connection, not the tank. There isn't a connection for the tank, just a cap.
Old 10-20-2018, 06:32 AM   #7
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
Ditto - distortion of the male end of the hose has happened to me a couple of times over the 18+ years we've been RVing. Try another hose just to see if that may be the problem.
Robert & Estha Shiflet
'17 Cardinal 3456RL - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 22
rjshiflet is offline   Reply With Quote
Old 10-20-2018, 06:52 AM   #8
I've found that a 90 degree brass connector helps a lot and takes the distortion off the connector.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 10-20-2018, 06:55 AM   #9
"On the road again"
rjshiflet's Avatar
Yep - good thought. I use one since the hose comes up through the bottom of the wet bay.
Old 10-20-2018, 07:09 AM   #10
hack522's Avatar
I had a similar situation last year and found out the connector was damaged when I blew out the system. Forgot to reduce the air pressure on my compressor. Changed it out this spring and all is good!
hack522 is offline   Reply With Quote
fresh water, leak, water, water leak
