Old 12-28-2017, 10:33 AM   #1
Davison206's Avatar
Water leaking from area at hot water heater
Coachmen Leprechaun 260ds....water seeping under baseboard by water lines connecting to hot water heater. Does not always happen. Wondering if it could be condensation? They are in such a tight space, we cannot check them.
Ed and Joyce and Luci Lou
2017 Coachmen Leprechaun 260ds
2017 Ford Escape
Master Tow Dolly
Davison206 is offline   Reply With Quote
Old 12-28-2017, 10:40 AM   #2
Not condensate. look for a leak. Might be pressure relief valve. had to replace mine this year. It is supposed to leak outside but may be running back in.
Old 12-28-2017, 10:44 AM   #3
Always Learning
You need to get it checked- either by you and becoming a contortionist or hiring a mobile RV tech.
If water is coming under the baseboard, it’s more than condensation.
In my case, the one way check valve at the inlet of the water heat had magically cracked and was dripping. The moment I put a wrench on it, it broke in 1/2. I spent more time trying to get the left over piece out than anything else.
But, water is bad. Get it looked at.
heater, hot water, leak, water, water heater, water leak
