Old 05-05-2010, 10:35 AM   #1
Water Line Material Question
I had a realization earlier this year that the H2O lines in my 5th whl look very much like the PEX H2O lines you can plumb your home with...is this right? If so, how many of you fellow RV owners carry spare fittings, pipe, and the special tools along for the ride? Any suggestions on what to keep in the tool box for emergency repairs?
Thanks, E.S.P.
E.S.P.
'07 Rockwood 8281SS 5th Wheel
'07 Silverado 2500HD LMM Duramax Diesel / Allison 1000 CC 2LT S/B
Reese 15K 5th Wheel Hitch w/ Kwik-Slide
E.S.P. is offline   Reply With Quote
Old 05-05-2010, 01:40 PM   #2
If the water lines are red and blue, they are PLEX. After being here over a year and a half, they give little trouble, just don't let them freeze. My old camper I kept plastic tubing and screw clamps for emergency, along with a flaring tool, but it was plumbed with copper tubing. Home depot carries a "sharkbite" style fitting that requires no special tools, may have some repair stuff in the size you need to build a repair kit, if it makes you feel better.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 05-06-2010, 12:24 AM   #3
Janitor
Sharkbites and a cutter are all you need.
dirtengineer is offline   Reply With Quote
Old 05-06-2010, 06:31 AM   #4
Head Rambler
And if you have a pocket knife the cutter is optional.
Gotta go campin!
Old 05-06-2010, 06:32 AM   #5
miatared's Avatar
OK, figured it out 1/2" . I also noticed that Home Depot in Canada also carries the WATTS QuickConnect line - more or less the same, but they are made of plastic - may be lighter.
What's the typical size for these little Sharkbites ?
I need to install my accumulator and my trailer is still in storage... 1/2 inch ?
Thanks.
Denis
miatared is offline   Reply With Quote
Old 05-06-2010, 02:57 PM   #6
Janitor
http://www.cashacme.com/prod_sharkbite.php
All you need to know about sharkbites.
Old 05-06-2010, 03:04 PM   #7
tmmar's Avatar
Sharkbite connectors work great! Very easy to use.
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-07-2010, 08:17 AM   #8
The normal size used in most RV's is 1/2" id, and 5/8" od.
Jspafford is offline   Reply With Quote
