Old 04-08-2010, 09:18 PM   #1
Water line Size
Hi all,
I have a 2009 Surveyor 235RKS. I noticed today that when I filled the fresh water tank, it immediately began to drain. I am hoping this is the drain and not an overflow. It looks the a cap is missing. What size line is it? Looks 3/4 inch.
Any help is very appreciated.
Scott
smib is offline   Reply With Quote
Old 04-09-2010, 05:42 AM   #2
Herk7769's Avatar
Is this the low point drain (should be a hot water drain next to it) or the fresh water tank drain (white plastic spigot)?
HAM CALLSIGN - KC3FFW
Old 04-09-2010, 06:28 AM   #3
Head Rambler
It's 1/2" NPT and the caps are hard to find.
The lines are 1/2" PEX. I replaced the caps on ours with pex valves. They're expensive, but now I don't have to remember where I put the caps.
Gotta go campin!
Old 04-13-2010, 07:51 PM   #4
Smib; When I picked up our new V-Cross, I had the same thing happen. I found they had stored the cap in the water heater compartment along with the anode rod, which was removed for the winterizing. I put a proper valve on the 3/4 drain to make it a little easier. If you do that, try to get a plastic valve. It won't shake around like the heavier metal ones.
WillyB is offline   Reply With Quote
