Old 05-11-2012, 10:57 PM   #1
Canadian Member
itat's Avatar
Water Line Valves
In my Roo 23SS the previous owner installed a tee in the line between the FW tank and the water pump so he could disconnect the suction side of the pump from the tee and feed antifreeze into the system when winterizing. I guess that was the only fitting he could find at the time.
Although it does work I'd like to reconfigure it and add a couple valves to the two inlets of the tee - one to the FW tank and the other side to short piece of hose to put in the antifreeze jug so I can use the valves to select the pump feed rather than having to pull the one line off the tee fitting.
What size and type of valves and hose should I use?
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
itat is online now   Reply With Quote
Old 05-12-2012, 12:09 AM   #2
Most all plumbing in a fairly new trailer is 1/2 inch pex, requiring a special crimp tool, and crimp rings. You can get the rings, and pipe at big box hardware. As for valves, I like ball valves, they work, and you can look at then and tell whether on or off, but really, your choice. As for feeding the antifreeze jug, I just use a piece of the clear plastic, 1/2 inch line, cheap stuff from Lowe's. Bought a few years ago, and still works. Even used a piece of it to replace my refer drain, since the other gave out due to weather, and being extremely cheap.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 05-12-2012, 07:24 AM   #3
Canadian Member
itat's Avatar
Thanks, windrider. The water line from the suction side of the pump to the FW tank is the flexible white hose type rather than pex. Checking around the internet and looking at what I have, if its 1/2" tubing then it looks like its a 1/2" x 1/2" x 1/2" flare tee with one port capped.
The simplest solution would be to replace the tee with a 3-way valve with the same flare connectors. I can probably pick up some extra hose at the local HD or Lowes but I might have to go to an RV dealer to get the 3-way valve?
Old 05-12-2012, 08:12 AM   #4
Triguy's Avatar
itat,
Is this similar to what the original owner installed?
If so, then it sounds like it should work without disconnecting and reconnecting hoses.
If not, its a simple solution and can be bought on amazon for $14.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-12-2012, 08:33 AM   #5
Canadian Member
itat's Avatar
No. It's just a tee in the line to the FW tank with the 3rd port capped. He would disconnect the pump intake from the tee and put it into the antifreeze jug.
Since I live in Canada, delivery is about $30 for anything ordered off Amazon.com so I'll need to see if I can find it locally.
Old 05-12-2012, 08:36 AM   #6
Triguy's Avatar
Ouch I forgot about that.
Its easy enough to make on your own and, anyway, it works better to install a longer hose. You can make a one like it with parts from the hardware store.
Scott
2012 Shamrock 233S
Old 05-12-2012, 04:52 PM   #7
Canadian Member
itat's Avatar
I found the 3 way valve at a local RV store. Just need a piece of hose to go to the antifreeze bottle.
Thanks for you help!
