Old 03-02-2009, 11:40 PM   #1
Water lines
Wandering if any one had the problem I had a week or so ago. on our last trip I noticed a little water was dripping around the water connection but it was coming from the inside. So looked back and the hose that attached on the inside was dripping. I reached in and tried to tighten but no luck. i pulled it apart and checked seal and looked good. put back together and notice everty connection on those types of hoses were leaking. Mine is set up with city coming into a T. the other side of the t goes to the pump and then to the water filter. All three were leaking. I tighten and no luck. So off to the hardware store. Luckily on my Cherokee they are standard 1/2" connection so was able to spend 28.00 for three hoses already made. They are the flex hoses used for kitchen sinks or toilets with 1/2" connections on both end. It seems to be fixed but not sure why all those other hoses were leaking. Everyone may want to watch those. My rig is only 2 years old and I am in Central tx so would not think it would of been a freezing issue. Is an easy fix
Don
Don Wilcox,
07, Cherokee, 295 5thwheel
2006 duramax
donawilcox is offline   Reply With Quote
Old 03-03-2009, 07:06 AM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Are the originals you replaced made of a plastic or nylon type nut? It's possible the threads inside the nuts had been damaged due to over tightening and over the period of time loosened. Did you try teflon tape on any of the connections before replacing the hoses. I've had this situation on my previous trailer. We were on vacation for a week and didn't have any leaks. After we got home I connected my hose to the trailer to flush out my tank and lines since our next trip was about 6 weeks later. I had 2 leaks similar to what you described. I tightened them and they still leaked but stopped once I used the teflon tape. We didn't have another leak for the remaining 2 years we kept the trailer.This trailer was a Keystone Litehouse though but the plumbing fittings most likely are the same.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 03-03-2009, 07:22 AM   #3
Head Rambler
All our piping is PEX but it sounds like those on yours aren't. Glad you could find replacments so easily. The ends of those hoses could have all been from the same run and there could have been a problem with the crimps or the ends themselves.
Gotta go campin!
Old 03-03-2009, 07:40 PM   #4
jjmoore's Avatar
Why leaking?
If they didn't leak while at a campground but did at home, perhaps the water pressure at your home exceeded the recommended 40 lbs of pressure for the rv plumbing. Did you have pressure regulator on at the time?
JJ & Peg
Felines Susie & Louie
2007 Sandpiper 341RLD
2005 Dodge 2500 TD
Equalizer Hitch
jjmoore is offline   Reply With Quote
Old 03-04-2009, 11:46 AM   #5
cfsoistman's Avatar
Yes I used the water pressure regulator. I have well water at home and the pressure tank tops out at 50 PSI. My regulator is attached to my hose even when I store it. It still is now with the motorhome ever since I left one behind on a trip.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 03-04-2009, 01:59 PM   #6
Mine leaked at the inlet to the Fresh water tank. It had an automotive type hose clamp that I tightened up, BUT it still leaked, so the tech at Dick Gore's RV world put silicone sealer on the connection, and then installed 2 auto hose clamps. So far, no more leaks.
Old 03-05-2009, 08:40 AM   #7
rafcar's Avatar
I had a similar problem a few weeks ago when I hooked up the water to the trailer at home, but I did it without the pressure regulator. I pulled the panel out to check the hose and I saw a small leak at one of the connections. After making sure it was tight, I turned the water back on, still no pressure regulator, and a tiny drop came out once and then it stopped. So now I'm wondering if something got damaged, or if it may be okay when I use the regulator.
2007 Forest River Cherokee 30F
* 14K Equal-i-zer hitch
* TST tire pressure monitor
2003 Chevy Silverado 2500HD Duramax
* 4" MBRP exhaust
* AFE stage2 air intake kit
* Hypertech III, set on stage1
* back-up camera
* Putnam XDR class V hitch receiver
* Airlift air bags
2004 EZGO custom electric golf cart
rafcar is offline   Reply With Quote
Old 03-05-2009, 09:36 AM   #8
cfsoistman's Avatar
Is it possible that there is air in the line? After that drip you may have had air that was coming out instead of water. I'd hook up that regulator, turn on the water hose and open all faucets to be sure you have removed all air and your leak is fixed. It's easier to deal with at home than on the road.
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 03-05-2009, 01:08 PM   #9
rafcar's Avatar
I will look into that. Thanks.
* 4" MBRP exhaust
* back-up camera
* Airlift air bags
Old 03-12-2009, 12:15 AM   #10
leaking lines
It has been a while since I have been back on. I did have regulator on so was not pressure. These hoses had ruber seals in the back. never had any luck with teflon on these types of hoses. the one spot did leake while camping but he others connections did not till I started messing with it. i may of had air in the lines but it was dripping pretty good.
Thanks for the imput.
Don
Don Wilcox,
2006 duramax
