Old 07-21-2015, 10:01 AM   #1
Water Lines
We have a 2006 Cherokee 28' while camping we notice a small leak under the trailer about where the fridge is using the fresh water tank. This passed weekend while hooked up to city water line we had a worst leak. Does anyone have any ideas on how to repair a water line? Or know how to remove the fresh water tank so we can see the water lines?
Summerfun2015 is offline   Reply With Quote
Old 07-21-2015, 01:33 PM   #2
bikendan's Avatar
How is the fridge using the FW tank?:what:
Equalizer WDH
Old 07-21-2015, 03:55 PM   #3
City water is much higher pressure than that of your pump. If you have a sealed underbelly you may have to remove part of it before tracking the lines. You may luck out and find a line leaking inside a cabinet without resorting to removing the tank.
phillyg is offline   Reply With Quote
Old 07-22-2015, 10:24 AM   #4
Thanks we are going to work on it this weekend. Wish us luck.
Old 07-22-2015, 10:44 AM   #5
Water leaks are hard to find,but since you say hooked up to (City Water) it gets worse leads away from your F/W tank! Drain your (Low Point Drains) and W/H! Now hook up a (Air Line) regulated to (40PSI) to your (City Water Con)! You will be able to (HEAR) the area where your leak is! Without all the (WATER)! Youroo!!
Old 07-22-2015, 11:43 AM   #6
Left Coast
Also, make sure you're using a pressure regulator when hooked to city water.
water
