We have a 2006 Cherokee 28' while camping we notice a small leak under the trailer about where the fridge is using the fresh water tank. This passed weekend while hooked up to city water line we had a worst leak. Does anyone have any ideas on how to repair a water line? Or know how to remove the fresh water tank so we can see the water lines?
City water is much higher pressure than that of your pump. If you have a sealed underbelly you may have to remove part of it before tracking the lines. You may luck out and find a line leaking inside a cabinet without resorting to removing the tank.
Water leaks are hard to find,but since you say hooked up to (City Water) it gets worse leads away from your F/W tank! Drain your (Low Point Drains) and W/H! Now hook up a (Air Line) regulated to (40PSI) to your (City Water Con)! You will be able to (HEAR) the area where your leak is! Without all the (WATER)! Youroo!!
