Old 11-27-2017, 02:20 PM   #1
Water not draining from shower tub
Hi all
I finally got the chance to try my new (to me) Wolf Pup 16FQ (2016). I went on a KOA campground with full hook up to check the systems, and everything seems to be ok.
The only problem is that when the the gray tank reached the 3/4 level (as per the inside check), the water stopped draining from the shower tub, which sounds kind of strange because as long as I can see the gray tank is way lower. And we got to 3/4 in a little more than a day with two people (two showers, dish washing, cooking and so on), which can be a problem if I go in a place without hookup. Any case discharging the tank was enough to have the water flow out of the tub.
Is that normal or could it be a problem somewhere in the lines?
iconnekt is offline   Reply With Quote
Old 11-27-2017, 02:27 PM   #2
SlowrideHD's Avatar
Inside level indicators are notoriously inaccurate. When it's full, it's full. Take Navy showers and learn to conserve what goes into grey.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 11-27-2017, 02:29 PM   #3
Scoundrel
HangDiver's Avatar
Originally Posted by iconnekt View Post
Hi all
The black and grey tank level indicators are notoriously inaccurate. Showers and washing dishes can fill a grey water tank (depending on the showers). Water not draining out of the shower basin is a pretty good sign the grey tank was full.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 11-27-2017, 02:42 PM   #4
PPST Wannabe
kenandterry's Avatar
Lights are for show.
If the water is backing up in the drain of the bathtub/shower.....youíre full.
Thatís the lowest point of your plumbing and it has no other choice but the gray tank.
ďStand back and pull the lever GeorgeĒ.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 11-27-2017, 02:57 PM   #5
And are you absolutely sure your shower drains to the gray tank? The shower on my 21DS drains to the black tank which is positioned directly under both the shower and the toilet.
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
windsurfdog is offline   Reply With Quote
Old 11-27-2017, 03:03 PM   #6
Man, that would not make me happy!
2011 Traverse LT, 3.6L, FWD
Old 11-27-2017, 03:52 PM   #7
Yeah...on the other hand, our gray water use is a bit more than black water use so there's a bit of "lemonade". Also, some soapy water added to the black tank would be beneficial.
Most camping for us is at campgrounds so it really doesn't matter much to us since we use campground showers. Boondocking could be a different matter.
2016 Microlite 21DS
Blue Ox SwayPro
Old 11-27-2017, 05:01 PM   #8
Oh boy... Well, if I can judge from the color, that was gray water... I really hope it was!
(...checked the tubing: yes, it's gray )
Old 11-29-2017, 12:05 AM   #9
OscarsMom2's Avatar
Your gray water tank is full. Since you have full hookups, connect the sewer hose and drain the tank. Don’t trust the monitor panel. They aren’t very accurate.
2020 Rockwood 2608BS
2017 Wildcat Maxx 26BHS
2016 Rockwood MiniLite 2503S (2015-2016)
2012 Ford F-150 Eco-Boost
OscarsMom2 is offline   Reply With Quote
Old 11-29-2017, 07:58 AM   #10
Wolverine 1945's Avatar
Originally Posted by OscarsMom2 View Post
Your gray water tank is full. Since you have full hookups, connect the sewer hose and drain the tank. Donít trust the monitor panel. They arenít very accurate.
X2 !!!
Wolverine 1945 is offline   Reply With Quote
Old 11-29-2017, 08:15 AM   #11
ben31's Avatar
Sorry, going slightly askew of the topic.
You now know how much water you use over a given time frame. It takes most people longer to figure that one out. If you really want to go longer between drains, you next need to start doing things to conserve that tank capacity. Most are normal for drought areas, but here are some hints. Take shorter showers. Turn the water off, while lathering up (there should be a button on the shower head to do that) - notice, turn the shower head away from you, when you turn it back on...you don't want to get a very hot or very cold blast of water! Don't let water run in the sink for longer than you absolutely need to in order to rinse things, etc. Use less water to wash the dishes. Don't let the water run, while brushing teeth, etc. If you do these things, you will notice you can go much longer between tank drains.
I only offered these suggestions, because you mentioned you may someday want to boondock or stay where there aren't sewer hookups. You can find other suggestions on Youtube and by searching the forums for ways to conserve water.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2008 F250 Lariat SuperCrew 4X4 6.4 Diesel
Never Enough Time Camping!!
ben31 is offline   Reply With Quote
drain, show, shower, water
