Old 04-25-2016, 07:50 PM   #1
Water pressure
We have 2013 sanibel 3501. When hooked to campground city water supply with a pressure regulated installed at the hose , our water pressure for showers is very low. My question is ; with the pex plastic water lines installed on the trailer , is it necessary to use a pressure regulated. Thanks for the help.
chris woznica is offline   Reply With Quote
Old 04-25-2016, 07:54 PM   #2
B and B's Avatar
I often have to take the regulator out. A Inline water filter provides some reduction in pressure as well I have a Water Softener so I have enough restriction.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 04-25-2016, 08:03 PM   #3
Flybob's Avatar
I would always use one as some campgrounds can have very large variations in pressure. If you get near the feed point in a very large campground, you could get very high pressure. The higher end regulators have adjustable flow rates. This is the one many people use ( not endorsing any seller). Water Pressure Regulator with Gauge on Sale - PPL Motor Homes
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-25-2016, 08:03 PM   #4
If the water pressure isnt over 60psi you wont need a pressure reducer.
dryhorn2 is offline   Reply With Quote
Old 04-25-2016, 08:23 PM   #5
bubbles's Avatar
A watts preset 50psi regulator and a 5/8 hose will maintain a safe pressure while allowing maximum volume flow. Neither is expensive. Then it's up to what type faucets you have. Some faucets are water saver type and an RV doesn't need those. JMO
Old 04-25-2016, 08:37 PM   #6
The Valterra A01-1113VP Hi Flow Water Regulator should put you in the 50psi range.
Check the reviews on amazon.....
2015 Forest River Grey Wolf..Traded
2015 Forest River Cherokee 274RK
2001 2500hd
2014 Jeep SRT...did not trade
Simplewon is offline   Reply With Quote
Old 04-26-2016, 06:53 PM   #7
Charles Firth's Avatar
I always check the water pressure at the hydrant with my trusty Home Depot water pressure gauge before hooking up. City water at my home is 60 psi haven't found a campground over 45 psi. I take several readings at different times if it remains 45 or under I don't use a regulator. I am still new to camping and after set up I walk the area to see what people are using, I see very few pressure regulators and surge protectors being used. Just a noisy observation.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
Charles Firth is offline   Reply With Quote
pressure, water
